02-10-2012, 11:16 AM
#16
Electrical Contractor
Multiple Ground Rods, help
If you are worried about a ground I would make sure you have two 8 foot ground rods with a continuous run of #4 wire and connect it to your main panels ground/neutral buss.
4 foot rods sound like a waste of time to me.
02-10-2012, 02:14 PM
#17
Ok, it sounds like I'll be running some copper wire from my new subpanel and connecting it to the existing 8ft ground rod and then on to the new 8ft ground rod (continous).
Is there any issue with having a gradual bend, as I'm depicting, with the new copper wire?
Thanks, Ralph
02-10-2012, 02:17 PM
#18
Licensed electrician
You do not run from the subpanel. Your grounding comes from your service panel.
The grounding for the subpanel is in the 4 wire feeder from the service panel.
02-10-2012, 04:11 PM
#19
It was a dark and stormy
Originally Posted by plummen
This way has always made sense to me anyway
This arrangement gives you a Single Point Ground (at the service box), which probably has no electrical disadvantages.
02-10-2012, 04:31 PM
#20
In the sketch shown in post 18 both the conductors from the panel to the 8' rod and from the phone to the conductor going to the 8' rod are correct. Just add a piece of #6 from the first rod to another 8' rod driven at least 6' from the first 8' rod.
02-10-2012, 06:35 PM
#21
Jim, do you mean add another rod so he has a total of three 8' rods?
02-10-2012, 06:55 PM
#22
No, just connect the two 8' rods with a piece of #6.
02-10-2012, 08:33 PM
#23
K thanks, I saw that wire connecting the 2 rods 18" below the surface and was confused.
02-10-2012, 09:15 PM
#24
I interpreted that as coming from the sub.
02-10-2012, 09:35 PM
#25
Thanks Jim,
I'll run a new copper ground wire from the load center neutral buss to the existing 8ft ground rod and then on to the second 8ft ground rod.
If someone could answer this question as it has yet to be addressed.
I do prefer to run a second copper ground wire from the load center to the ground rod due to noted concerns with existing copper wire (bends & size). If for no other reason piece of mind.
Anyhow, is a gradual bend as I've depicted in post #18 ok? It is shown as coming from the sub panel but will actually come from the load center.
God Bless
02-10-2012, 09:40 PM
#26
Ralph, there is no need to go back into the panel buss. You can just jumper between the two rods.
As far as the bend, why not come straight down and place the sweep under the dirt? I think it would look better. The way it is installed with the off angle bend would drive me nuts as it looks like someone did not care what it looked like. Functionally it is fine.
02-10-2012, 10:27 PM
#27
Just to confirm:
I should simply connect the two ground rods together and you feel the existing copper wire, running from the meter, is perfectly fine.
I will address the bends however as that was a tacky way of doing it.
Take care.
02-10-2012, 10:46 PM
#28
Originally Posted by Ralph III
Just to confirm:
Take care.
Your utility is fed underground. That means your risk of transient damage is much lower than an aerial fed power line. I think you are solving a problem that doesn't exist.
The Following User Says Thank You to curiousB For This Useful Post:
02-10-2012, 11:25 PM
#29
Well maybe, but I'd rather be safe than sorry especially considering how cheap it is to add a second ground rod.
Just FYI, that underground utility feed to our house comes from overhead wires and a light pole about 30ft away.
Take care,
Ralph
02-11-2012, 10:46 AM
#30
Take care,
Ralph
Still, I'd think that the underground part would act like a distributed resistance and distributed capacitance and so somewhat lessen the effect of a lightning strike.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
