Old 07-08-2008, 07:09 PM   #1
Question
multiple fixtures wired on a switch loop
I would like to wire multiple light fixtures on a switch loop. I understand wiring one fixture, but I am confused when I consider additional fixtures. There doesn't seem to be enough wires coming from the first fixture. I am using 2-wire cable. Do I need a length of 3-wire cable also? I have not attempted to wire this yet. I have only drawn my own diagrams, and can't figure it out. Is this even possible?
Thanks,
Chad
brotherman is offline   Reply With Quote
Old 07-08-2008, 08:30 PM   #2
Is this a 3-way switch system?
Regardless, you simply daisy-chain the light fixtures using 2 wire (plus ground of course) between the fixtures.
You need 3 wire cable between 3-way switches though.
FW
fw2007 is offline   Reply With Quote
Old 07-08-2008, 09:42 PM   #3
Electrician
Thanks,
Chad
If the feed is at one end of the lights and the switch leg is on the other end, than yes you need a 3 wire between the fixtures.
chris75 is offline   Reply With Quote
Old 07-08-2008, 09:58 PM   #4
joed's Avatar
You need three wire cable. It looks like this when wired.
Old 07-08-2008, 10:04 PM   #5
Electrician
Heres a few examples...
Old 07-09-2008, 04:21 PM   #6
Sorry about my ignorance. I was assuming the feed was from the switch. I should never have assumed this, since I have seen it the other way many times.
FW
Old 07-09-2008, 04:47 PM   #7
Electrician
FW
The OP said he was using a switch loop.
Old 07-09-2008, 10:46 PM   #8
Thanks to everyone for your help.
Thanks,
Chad
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 07:04 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
switch loop aokss Electrical 13 05-07-2007 09:41 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
Voltage Drop between switch and fixtures CaptMike Electrical 1 06-24-2005 10:30 PM
