Multiple Feeds On 14/3 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2006, 01:49 PM   #1
Post
Multiple feeds on 14/3 wire
I climbed into my attic to check out the possibility of adding a bathroom fan the other day and had the pleasure of finding some wiring which looks like it was completed by a 16 year old hooking up a car stereo. 2 places in my attic there are junctions that are wire-nutted and taped and are not enclosed in a box. I have fixed them both by enclosing them but I have a question about how a circuit is wired. It looks like an additional circuit was added to feed can lights in my kitchen. The feed for the original fixture which is now a fan was rerouted to feed the can lights on a 3 way switch. This feed comes from the other side of the room and all looks well. The new feed (to replace the feed to the fan) is spliced off a hot wire in the attic and feeds a switch and then on to the fan. A piece of 14/3 was used to get power from the 3 way switch to the can lights on the red wire. It passes through my new junction box and on to the can lights. The other leg of that 14/3 (black) is used to feed the switch that operates the fan (it picks up power from wires passing through my new junction box and runs down to the switch and back to the fan on a piece of 12/2) The question is - is it to code to have 2 sources in the same junction box and is it kosher to use different leads in the same cable to feed different fixtures. This is all on one breaker.
roadhouse1301 is offline   Reply With Quote
Old 11-09-2006, 04:25 PM   #2
World famous jerk.
Yes, and yes. You're fine.
mdshunk is offline   Reply With Quote
Old 11-10-2006, 12:16 AM   #3
Thanks for the reply. Our home inspector brought these issues to our attention when we bought the house but I didn't realize the extent of their shoddy wiring until I proceded to repair it. I just wanted to ensure someone down the road isn't making similar commentary about my fix.
Multiple lights/ceiling fans on 14/2?? sleepy23 Electrical 5 05-10-2007 10:27 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
