Multiple Electrical Failures - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 09:30 PM   #1
Multiple electrical failures
Our Hvac compressor, spa and bathroom light and plugs all went out on the same day - should we check power surge or lightning damage with insurance company?
dkd1972 is offline   Reply With Quote
Old 07-25-2011, 09:35 PM   #2
what caused it?
Old 07-26-2011, 06:59 AM   #3
Rewards Points: 1,542
You need to check the wiring, testing for the proper voltage (120 volts for lights, ordinary receptacles), testing between hot and neutral. The air conditioner circuit nees to mearusure 240 volts between the two hot wires.
Start at the breaker and work along the circuit in case you run into loose connections where the circuit wire goes into an outlet box and then continues on to another outlet box or switch.
Old 07-26-2011, 08:41 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,512
Sounds like you lost a branch or a phase.
Loose connections are also possible.
Faulty breaker / switchgear.
Even a surge on one phase only.
Call the insurance company and find out there procedure,
You will probably need an electricains report.
dmxtothemax is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Electrical Failures in House Rafterman414 Electrical 8 01-23-2009 07:00 PM
