Multiple Coax Tv Cable Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2008, 09:13 AM   #1
Multiple coax tv cable outlets
Hello,
I've got one Satellite Dish, with a single LNB...I also have three bedrooms that I'm renovating and would like to install TV outlets in each. Ultimately I'd like seperate Satellite Receiver's in each room. Can I do this with only one dish, if so, How?? I'd imagine I'd have to split the cable three ways?
This seems to be a simple question but its got me puzzled. Thanks for the help!
Bryan
flyultralite is offline   Reply With Quote
Old 11-25-2008, 09:24 AM   #2
Res Ipsa Loquitur
Can't speak about satellites but from experience with cable service I would suggest you home run all cables to a common area that you can have connections (attic, utility closet) or place a entertainment junction panel. There you can determine how you best manage those rooms. From my narrow understanding of satellites-- I thought they needed an LNB per single output connection?? That might be why I see homes in my area with multiple dishes and also dual LNB's per dish.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 11-25-2008, 09:29 AM   #3
Rewards Points: 862
I'm not all that familiar with satellite Tv, but I agree with Handyman78 about Home running each cable to a common tie point. You'll have lower losses that way, plus the convenience of single point access.
I do believe there are sat dishes that allow multiple receivers, but not sure you can upgrade a single to a multiple.
Ultrarunner2017 is offline   Reply With Quote
Old 11-25-2008, 09:41 AM   #4
You would need a special LNB or two LNB's, a multiswitch, and a receiver for each TV. Ask your satellite TV provider.
Below (link) is a frequency list of a Dish satellite. Notice each listing says "R" or "L". This is "polarity". The receiver sends a voltage to the LNB telling it to use R or L. If one TV is set to R, the other TV could not switch to a channel which uses a L. This would conflict.
A Dish Satellite frequency list...
http://www.lyngsat.com/packages/dish61.html
With a special LNB or two LNB's, one could be set to R and the other to L. The multiswitch would use the appropriate LNB for whichever channel you wanted.
One of many multi-switch diagrams...
Billy_Bob is offline   Reply With Quote
Old 11-25-2008, 12:15 PM   #5
Use QUAD shield!
Use compression connectors.
rgsgww is offline   Reply With Quote
Old 11-25-2008, 12:18 PM   #6
DIYer
Originally Posted by rgsgww View Post
Use QUAD shield!
This is much much less important than just running normal, low-loss RG-6 from a reputable source.
I'd almost go as far as to call it a gimmick.
Gigs is offline   Reply With Quote
Old 11-25-2008, 01:05 PM   #7
47_47's Avatar
Rewards Points: 44
Just my .02 worth, home run the system to a centralized location, as the others have said. Check with satellite providers. I need two RG-6 cables to watch one station and record another (DVR).
47_47 is offline   Reply With Quote
Old 11-25-2008, 02:09 PM   #8
I should probably revise my answer...depending on your location (like a city, or near a radio broadcasting place) you may use quad or rg/6.
Really depends on the amount of emi or rfi in the environment.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
Multiple cable runs wease Electrical 11 02-12-2007 12:40 AM
