Multiple Circuits In Same Octagon Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 09:58 PM   #1
Rewards Points: 14
Multiple Circuits in Same Octagon Box?
Just have a quick question about circuits in an octagon (light fixture) box...
I`m wondering if its possible to have multiple circuits in the same box. I`m adding a light fixture to a room which will be controlled by a switch, and at the same time I`d like to use the same box as a junction box to join 2 wires from another switch... Everything will be from the same power supply. Below is a diagram of what my question is.
Basically, I will avoid a lot of extra work by keeping it this way instead of opening up walls and creating more work and running a direct like from switch 2 to the exterior light...
Any thoughts or comments?
EDIT - Just to add, needs to be Canada electric code
ldogg is offline   Reply With Quote
Old 01-02-2011, 10:01 PM   #2
Yes you can use the same box for different circuits
Grounds must be tied together
....ah...Canada may be different
Might want to add that info to your profile
from the same power supply...as in same circuit breaker ?
Old 01-02-2011, 10:06 PM   #3
Rewards Points: 14
Yes, they will all be on the same breaker... I was hoping to tie it all together, but with the need for a seperate switch, I will have to bring in another power supply line from the same circuit.
Old 01-03-2011, 06:46 AM   #4
If the switches are located together and on the same circuit, why don't you use a run of a 12/3 or 14/3 from the switches?
clashley is offline   Reply With Quote
Old 01-03-2011, 08:03 AM   #5
Rewards Points: 1,542
The most common, and very common with an octagon box, is having it become too crowded. Using your diagram and U.S. calculations, you would probably need at least a 20 cubic inch box. One point for each hot or neutral wire end coming in, one point for all the clamps if any protrude into the box, one point for all the ground wires, 2 c.i. per point for 14 gauge, 2-1/4 c.i. per point for 12 gauge.
Aside from that, it is even okay to have different circuits coming into the same box.
To have more space, you may be able to get a ring (bottomless box of the same width and shape) to put over the front of the existing box and then put the cover plate on the front of the ring.
Old 01-03-2011, 10:07 AM   #6
joed's Avatar
Rewards Points: 13,354
Same power supply indicates same circuit. No problem putting them in same box.
No problem putting different circuits in same box. Connect all grounds together. Keep neutrals separate.
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 09:06 AM
Multiple circuits losing power Skip72 Electrical 6 09-20-2010 10:27 AM
Multiple Circuits needs The Layman Electrical 27 05-20-2010 12:00 PM
Multiple circuits in one box? jdc1040 Electrical 8 07-23-2009 10:00 AM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
