Multiple Circuits - Same Box With Grounds - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 01:36 AM   #1
Multiple Circuits - Same Box with Grounds
If I have two different circuits coming into a box, is it kosher to connect all grounds, even if they cross circuits? I haven't been, but was just thinking it might not matter either way . . .
Shaotzu is offline   Reply With Quote
Old 05-19-2011, 01:47 AM   #2
Rewards Points: 506
"even if they cross circuits" ?? Not sure what that means.
Grounds from different circuits can be spliced in a junction (or switch, or receptacle) box. They should also attach to any grounded switch and on receptacles.
The Following User Says Thank You to sirsparksalot For This Useful Post:
Shaotzu (05-19-2011)
Old 05-19-2011, 02:11 AM   #3
I think that answers it, but in a box, I have two cables that are carrying power in to the junction box from different circuit breakers (lights and receptacles are on different circuits, and they happen to meet in this box). I was just making sure that I could connect all the grounds from Circuit 1 and Circuit 2. Logically, I think it makes sense, but just wanted some validation in case there was either some risk I wasn't aware of, or some code issue that would pop up that says you can't connect grounds for some reason if they are on different circuits from each other. (All is still 15A service on 14/2 wire)
Old 05-19-2011, 02:20 AM   #4
Rewards Points: 506
it's all good. grounds connected and pigtailed to receptacles or switches where possible.
Old 05-19-2011, 02:51 AM   #5
Thanks! That's what I figured, but I'm planning on calling for inspection tomorrow, and I've learned not to assume with respect to electricity.
Old 05-19-2011, 05:18 AM   #6
Licensed electrician
Rewards Points: 1,020
Yes, the grounds from all the circuits get tied together.
Old 05-19-2011, 10:22 AM   #7
Rewards Points: 1,418
The difference is that you do not connect the neutrals of the different circuits together. The neutral for each load is connected only to the neutral that accompanies the hot line serving that load. That is, there must be only one possible neutral path from any load back to the panel and it must accompany the matching hot.
Old 05-19-2011, 01:06 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,858
Not only can they be, they should be. All grounds in any one location should all be connected together, and to the enclosure if it is metal. The more simultaneous ground paths, the better.
mpoulton is offline   Reply With Quote
Old 05-20-2011, 05:40 PM   #9
Makes complete sense! Thanks guys! And... Inspector came out yesterday and cleared the work.
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 05:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
Multiple Circuits in Same Octagon Box? ldogg Electrical 5 01-03-2011 11:07 AM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 10:06 AM
Multiple circuits losing power Skip72 Electrical 6 09-20-2010 11:27 AM
