Old 09-17-2012, 05:54 PM   #1
Multiple circuits
I am building a power source for a hayride and I need four outlets on four switches all running from one power source. How do I connect them all without interfering with each other?
Chad Ferguson is offline   Reply With Quote
Old 09-17-2012, 06:05 PM   #2
Rochsolid's Avatar
Multiple circuits
If all switches are in the same box, bring power into the box, then make 4 pigtail going to each switch, then bring a whip out to each plug as put each hot wire from the plug on the switch which you wish to use to control that olug
Rochsolid is offline   Reply With Quote
Old 09-17-2012, 06:48 PM   #3
Lic Electrical Inspector
electures's Avatar
Multiple circuits
Use four of these;
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 09-17-2012, 07:34 PM   #4
Multiple circuits
Is you power coming into the switch location?
hammerlane is offline   Reply With Quote
Old 09-17-2012, 07:40 PM   #5
A "Handy Husband"
rjniles's Avatar
Multiple circuits
Better be a short hayride or you will need a long extension cord.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
stickboy1375 (09-17-2012)
Old 09-17-2012, 07:43 PM   #6
Multiple circuits
Or if you have the power coming into one of the receptacle locations, do the following.
NOTE..I did not show ground wires in any of the diagrams for ease of drawing
Old 09-17-2012, 07:53 PM   #7
Multiple circuits
This scenario is a pretty easy figure out with just a very basic understanding of electrical...like electric 101 basic. So I ask that you be careful since I assume others will be involved in this hayride.
Controlling multiple circuits from a single timer? clashley Electrical 4 12-05-2011 09:09 PM
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 05:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 10:06 AM
Multiple circuits losing power Skip72 Electrical 6 09-20-2010 11:27 AM
