Old 07-19-2008, 10:38 AM   #1
Multiple 4 way switches stopped working
I installed the light circuit in my garage with 4 way switches so I could turn the lights on/off from each entrance. They worked fine for about 6 months and then started not working. At first I thought that a switch had not been thrown all the way to the other position and I would cycle all switches and get the lights to come on. No one switch seemed to fix the problem. Now they will not come on no matter how many times I flip all switches. All switched were new when installed.
Keniki is offline   Reply With Quote
Old 07-30-2008, 12:02 PM   #2
Well I fixed the problem. I bought a 3 way and a 4 way switch and just started replacing them. If the one I replaced did not fix the problem, I used it in the next position. When I changed one of the 3 way ones, the problem went away.
Old 07-30-2008, 12:38 PM   #3
Electrical Contractor
4-way swiches are only used between two 3-way switches.
hpp58 is offline   Reply With Quote
Old 07-30-2008, 02:34 PM   #4
Right. I had 2 3 way switches with 2 4 way switches in between them. One of the 3 way ones was not making contact or something so I replaced it with a new one and the system works fine again.
Thanks for the reply.
Keniki
Water Dispenser Stopped Working dgoldb1 Appliances 20 05-16-2011 06:48 PM
Light switches not working marc633 Electrical 7 07-22-2008 06:34 PM
Multiple switches for a ceiling fan dmr7547 Electrical 10 03-04-2008 04:25 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
Light Stopped Working gershon Electrical 5 01-10-2007 09:03 PM
