Multiple 220 Outlets Wiring Help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 02:27 PM   #1
Question
multiple 220 outlets wiring help
Here's the details.
I am renting an office in a warehouse. I need to installed 2 - 220 20amp outlets for my computer servers. the length of the run is 76ft. there is 4 90 degree bends in the run. All the existing electric is run above the office ceilings and is in rigid or flexible metal conduit. I have run a few 110v circuits but never any 220v.
My questions:
do I run one 220v, 40amp circuit or 2 - 220v - 20 amp circuit.
what kind of conduit ( pvc, rigid metal, flex metal)?
what size conduit?
What size wire?
solid or stranded wire?
if i run 2-220v, 20 amp circuits do i run two whites and two grounds?
my current thinking on this is to run one 220v, 40 amp circuit. the run will terminate on top of the wall above where I need the outlets. i would split the circuit there and run the two legs to the outlet boxes in the office wall.
I would use 3/4" pvc conduit and pull 4 #08 wires, red, black,white and a ground. I would use 3/4" flexible plastic conduit to run the outlet legs down the wall to the outlet boxes.
any and all answers and comments appreciated.
TIA
Apex
Xapex is offline   Reply With Quote
Old 10-23-2010, 03:53 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Since this is a commercial space you are renting you have no choice but to either hire a professional to do this, or have the LL hire someone.
DO NOT mess with the electrical systems in a place you do not own!
I will say, your "current thinking" is fatally flawed.
Two 20A circuits does not equal one 40A circuit.
Old 10-23-2010, 06:19 PM   #3
Just call me Andrew
Rewards Points: 1,020
Speedy is right - hire a professional or risk hurting yourself and/or your computer equipment.
Andrew
secutanudu is offline   Reply With Quote
Old 10-23-2010, 09:52 PM   #4
" Euro " electrician
frenchelectrican's Avatar
To OP I did see your statement and I allready reply in the other fourm and I will repeat in here just get a electrician and they will deal with it due it a commercal building and the DIY forum will not tell you what to do in commercal building beside hire a electrician.
And the question you been asking that kinda raised red flag allready to moi.
Merci.
Marc
Old 10-25-2010, 09:25 AM   #5
Thanks you all for your input
Wiring outside outlets. luweee Electrical 13 08-29-2010 11:15 PM
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 05:35 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 04:52 PM
Wiring to multiple bathrooms question budde97 Electrical 2 02-17-2007 01:57 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
