Multiple 15 Amp Recepticles - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2007, 11:52 PM   #1
Post
multiple 15 amp recepticles
I am wiring several new 15 amp recepticles. My question is can I wire them in series using the connnections on the recepticle or do I have to splice and pigtail each recepticle?
lfd219 is offline   Reply With Quote
Old 01-30-2007, 02:30 AM   #2
jproffer's Avatar
Rewards Points: 716
Two schools of thought on this one:
1: All rec.'s should be pigtailed to keep the nuetral intact during repairs/maintenance.
2: Doesn't matter because there's no reason to work hot circuits in a residential setting anyway.
I'm in the #2 group.
Legally, (UNLESS it's a local ammendment, check before deciding your course of action) there's no requirement to pigtail receptacles in residential installations.
jproffer is offline   Reply With Quote
Old 01-30-2007, 08:00 PM   #3
Rewards Points: 339
If the new recepticles are part of a multiwire branch circuit then pigtailing the neutrals is requried. You would also pigtail if there where more than two wires you needed to tie together at that box. Otherwise it is not required. Some will suggest that it is better workmanship to always do so, but life jpoffer above, I find they're arguments unconvincing.
LanterDan is offline   Reply With Quote
Old 01-31-2007, 09:08 PM   #4
remodeling pro
I personally like pig tailing, but as long as you use the screw terminals, I don't see a problem with the other. Do not use those trash stab in holes on the recepticle, they are good for nothing but trouble later on.
troubleseeker is offline   Reply With Quote
Multiple projects - what order? dsr3 General DIY Discussions 10 07-11-2007 08:14 PM
Multiple lights/ceiling fans on 14/2?? sleepy23 Electrical 5 05-10-2007 10:27 AM
Multiple cable runs wease Electrical 11 02-11-2007 11:40 PM
Is it OK to tape by multiple pieces of tape on one length? KUIPORNG Remodeling 3 01-21-2007 12:17 PM
How many recepticles Barry Electrical 7 12-14-2005 10:20 PM
