Multimeter Vs Potentiometer - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 08:46 PM   #1
Rewards Points: 264
Multimeter vs Potentiometer
Playing around with electronics, little confused on something.
If two resistors in series, the potentiometer gives .2 miliamps after the first resistor and .1 milliamp after the second. My multimeter just says 3 volts everywhere though.
Does this mean that:
- a potentiometer measures current, which is lowered by resistors.
- a multimeter meter measures voltage, which is constant throughout the circuit
Is this true? Like, if I have a 9volt circuit, and insert a 10k resistor, is it still 9 volts after the resistor?
tibberous is offline   Reply With Quote
Old 09-03-2011, 08:52 PM   #2
Rewards Points: 6,652
A potentiometer does not measure anything. Think of it like the dimmer switch for your dining room lights. As for a multimeter, it is a tool that can be used to measure amps, continuity, Ac or Dc voltage. Next time, do your own homework. Here, this will help you with your questions. http://www.allaboutcircuits.com/vol_1/index.html
The Following User Says Thank You to gregzoll For This Useful Post:
Code05 (09-03-2011)
Old 09-03-2011, 08:57 PM   #3
I=E/R
a7ecorsair's Avatar
If the resistors are in series the current will be the same through all components in the series circuit. To measure current, the meter is also placed in series with the circuit.
A potentiometer is a variable resistor
A multimeter can measure voltage, current, and resistance. Current is constant in a series circuit, voltage drop occurs across components in the circuit.
Yes to your last question. The 10K resistor will drop 9 volts.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Code05 (09-03-2011)
Old 09-03-2011, 08:59 PM   #4
Rewards Points: 1,192
Amperes the way you want to read have to be read in series.
bobelectric is offline   Reply With Quote
Old 09-03-2011, 09:01 PM   #5
Rewards Points: 264
I'm using the electronics learning lab from radio shack - which refers to the meter as 'meter'. It measures current, so I'm guessing it's called an ammeter?
Guess the question I still have is, do resistors change voltage?
V = I * R , so it would make sense that changing the current would change the voltage. It doesn't appear to work that way though - the voltage stays 3, regardless of resistor, according to my multimeter.
Old 09-03-2011, 09:03 PM   #6
http://www.csgnetwork.com/ohmslaw2.html
Here is the U.S. Army basic fundamentals of AC & DC. http://www.scribd.com/doc/3006265/TC...iples-of-AC-DC It is a lot better resource, than that Ratshack material that is pretty much out dated, and some parts of that book's printed material is actually incorrect in a few spots.
Code05 (09-03-2011)
Old 09-03-2011, 09:07 PM   #7
I=E/R
a7ecorsair's Avatar
Is the power for this learning lab provided by two 1.5 volt batteries?
A meter that strictly measures current is an ammeter.
Old 09-03-2011, 09:16 PM   #8
Rewards Points: 264
No, it takes 6. It has breadboard with different voltages across the top rail.
I figured out what was going on too. The voltage never reads exact, it's just close to what it should be. When I added my resistor, it did drop, just not enough to notice. I added a much higher resistor and was able to see the voltage drop.
Old 09-03-2011, 09:23 PM   #9
I=E/R
a7ecorsair's Avatar
In this circuit no matter what size resistor is installed, the voltage on the meter will be 3 volts but the amount of current flowing will change according to ohms law.
Old 09-03-2011, 09:26 PM   #10
I=E/R
a7ecorsair's Avatar
In this circuit the current will remain constant. The voltage measured on the wiper of the potentiometer will change as the knob is turned.
Westchester, NY: Where can I locally buy a multimeter with MFD testing support? Deck Electrical 6 07-22-2011 07:55 PM
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 08:55 AM
Basic multimeter usage 2Charlie General DIY Discussions 5 07-30-2010 03:24 PM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 08:10 AM
Ceiling fan + potentiometer question mothra Electrical 4 04-21-2009 01:11 PM
