Multimeter Use - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 05:36 PM   #1
multimeter use
Hello: I have a Sperry 350A multimeter and I am trying to check on a motorcycle rectifier. The current setting I'm using can be found with this image
And this is the measurements I am looking for. So is this the best setting to perform these measurements?
buddyface is offline   Reply With Quote
Old 10-18-2010, 08:17 PM   #2
Rewards Points: 330
you are on 2 volt dc scale.you want ohms scale.set it to 200 ohms.200 ohm scale is just below 2k
oleguy74 is offline   Reply With Quote
Old 10-18-2010, 08:52 PM   #3
Thanks so much for the direction. I saw the diode sign on the multimeter dial but why it never clicked given the symbol from the manual and the symbol on the meter is just goofy on my part. The rectifier seems fine so I'll check to see if the bike is charging off the stator next.
thanks again. I'll post here and give you an update.
Old 10-19-2010, 10:29 AM   #4
Rewards Points: 168
How did you check the rectifier? Rectifiers and diodes are not the same. Rectifiers convert AC to DC. Diodes allow current to flow in one direction only. Rectifiers are tested with the voltage setting (ac & dc) while diodes are checked using the diode function.
Old 10-19-2010, 01:34 PM   #5
Rewards Points: 156
Rectifiers are just diodes in certain configurations.
A "half wave" rectifier is just a diode placed in series with an AC circuit.
A "full wave" rectifier is a combination of diodes placed in series with an AC circuit.
You can test each "leg" of a full-wave rectifier to see if each diode is working correctly.
(more info: http://www.play-hookey.com/ac_theory/ps_rectifiers.html)
moondawg is offline   Reply With Quote
The Following User Says Thank You to moondawg For This Useful Post:
J. V. (10-20-2010)
Old 10-19-2010, 03:29 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
that would depend on how the rectifier is constructed. If it is an IC, chances are there is no way to check individual components of the unit.
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 08:55 AM
Basic multimeter usage 2Charlie General DIY Discussions 5 07-30-2010 03:24 PM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 08:10 AM
How to use a multimeter to tell which one is red? dtc HVAC 1 10-13-2009 05:52 AM
How to use a Digital Pocket Multimeter (to test AA & AAA batteries) ? ehoez Electrical 5 09-01-2008 11:02 AM
