Multimeter: Memory Trick To Remember (AC = House = V~) Vs. (DC = Car = V--) ? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 02:23 PM   #1
Rewards Points: 129
Multimeter: Memory trick to remember (AC = house = V~) vs. (DC = car = V--) ?
AC = house = V~
DC = car = V--
I only use my MM 2x a year, so it's not a habit.
How did you memorize this?
Any clever tricks/mnemonics?
Mathlete is offline   Reply With Quote
Old 12-17-2012, 02:30 PM   #2
Rewards Points: 150
Originally Posted by Mathlete View Post
AC = house = V~
DC = car = V--
AC is alternating current, the voltage moves up and down = ~
DC is direct current, the voltage does not fluctuate = ---
Dave632 is offline   Reply With Quote
Old 12-17-2012, 02:43 PM   #3
I have no special tricks for remembering a house is AC while a car is DC. I guess part of my core knowledge includes this bit of trivia. I also remember that batteries are DC, which tends to help me remember that car electrical systems are generally DC (at least when fed via the battery). I also pretty regularly notice on power supplies and electrical applicanes that input power is usually specified as AC (100-250VAC, 50/60hz, for example), which I take as a reminder that household power is, in fact, AC. The hum in some lighting and audio equipment could also act as a reminder that we are near AC power.
oberkc is offline   Reply With Quote
Old 12-17-2012, 04:22 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
AC = house = V~
DC = car = V--
Really not trying to be cruel or snide but if you can't remember that very simple thing, you should not be working on electrical equipment.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
brric (12-17-2012), Kapriel (12-24-2012), Kpack (12-17-2012)
Old 12-17-2012, 04:26 PM   #5
TTW
TTW's Avatar
Get a sharpie and write it on the back of your meter...
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-17-2012, 09:39 PM   #6
Engineer
Rewards Points: 161
To be honest I think the symbols are representative of what you're measuring as Dave632 mentioned.
diystephen is offline   Reply With Quote
Old 12-18-2012, 12:46 AM   #7
TTW
TTW's Avatar
Just remember AC - Atlantic City, lots of houses, it's on the wavy ocean ~ ~ ~ ~ ~~~~~~
DC - Death Certificate (you're flat) ---------------------------------------------
Daimler Chrysler is a car and it's nicer to drive on straight flat roads?
It's hard to Drive Carefully with a flat tire?
Just a try...
Asking an electrician is kinda like asking someone who drives a car what a stop sign looks like.
Try to think of something that will mean some to you personally.
The Following User Says Thank You to TTW For This Useful Post:
Mathlete (12-23-2012)
Old 12-18-2012, 08:10 AM   #8
Originally Posted by TTW View Post
...Asking an electrician is kinda like asking someone who drives a car what a stop sign looks like...
Right! Or which pedal in a car is the accelerator and which is the brake.
Things I use everyday, I remember. Things I seldom use, I forget.
With that said, I seldom wire up phone jacks. And I forget the wire color codes for multi-line cables (Lines 1, 2, 3, 4). With that said, I have a phone and cable TV tool box and in that tool box I have a printed sheet with those color codes on it.
So tape a note on your multimeter. Or if you keep it in a tool box, stick a note in there.
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
mpoulton (12-18-2012)
Old 12-18-2012, 08:27 PM   #9
Ahhh... remember the good 'ol days when multimeters simply said AC volts and DC volts? The symbols on my new fluke threw me off for a second or two as well after I first bought it and I've been using meters since I was a kid....
kwilcox is offline   Reply With Quote
Old 12-18-2012, 11:07 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Maybe you don't need to remember which is which....hook it up...try both modes...the one that gives you the highest value is most likely the mode you want to be in.....
Now...if your doing that with a battery....and you have it on AC.....you might want to start running.....the flux capacitor is about to go.
Old 12-19-2012, 07:33 AM   #11
Rewards Points: 506
I used my brain to memorize it. By the way, memorization is the simplest (lowest) form of learning.
jlmran is offline   Reply With Quote
Old 12-23-2012, 02:08 PM   #12
Rewards Points: 129
That is perfect, and exactly what I was looking for. Thank you!!!
I have memorized this 5 times, and I have forgotten it 5 times, b/c I use my MM about once every 2 years.
I have to re-Google this crap every time. No more!
Let's test myself right now:
AC = Houses = ~~
DC = cars = ----- (the dashes look like the highway divider marks)
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
