Multi Wire Branch Circuit ?? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 03:14 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I am planning on adding a 20 amp MWBC to my outbuilding. The distance from the new sub panel in my attached garage is about 60 feet. I am planning on burying 10-3 UF from the garage to my out building (24" deep). I have a good supply of the 10-3 UF on hand so that is why I am using it. 20 Amp 2 pole breaker in the sub panel. Now I get to my issue, I know I need a disconnect in the outbuilding and I have this on hand:
It is a GE TL412CP load center, 125 amp, 4 space, 8 circuit panel. My idea is to add a 20 amp 2 pole breaker with a hold down kit and back feed it with the 10-3 UF from the sub panel and 2 20 amp single pole breakers for the 2 20 amp circuits derived from the MWBC. I know that I will have to add a ground bar to keep the neutrals and grounds separate. I realize this is probably overkill but I have all the parts on hand with no other uses for them. I also realize that this fills the panel but I have no need for any additional circuits or capacity in this outbuilding.
Question: Is this a disconnect for a MWBC or have I just created another sub panel? If it is a sub panel I need to add ground rods which was not my original intent. Will not using the 2 pole breaker with the hold down but just use the 2 single pole breakers as disconnects for the MWBC make any difference? I have looked at my NEC but I will admit it is confusing me.
If it walks like a duck and quacks like a duck, must it be a duck?
Coastal South Carolina
Old 09-15-2011, 03:28 PM   #2
Code05's Avatar
Rewards Points: 1,104
2 pole breaker or 2 single poles with handle tie is fine.
You have created a sub panel, rods or such needed.
Why not a 30 amp breaker for the #10?
Code05 is offline   Reply With Quote
Old 09-15-2011, 03:32 PM   #3
Code05's Avatar
If you do not want to use rods, a double pole switch will work and no rods needed. No sub panel. 2 20 amp circuits in a MWBC.
Old 09-15-2011, 03:55 PM   #4
A "Handy Husband"
rjniles's Avatar
You have given me the answer I was suspecting I would get. I was trying to use up some of my spare parts which does not include any ground rods or #6 wire. I think you are right and take the easy route and use switch(es).
Old 09-15-2011, 04:14 PM   #5
Code05's Avatar
You send me the panel and I will send the switch. Deal?
Old 09-15-2011, 04:17 PM   #6
Code05's Avatar
2 single pole 20 amp switches would be legal also as disconnects if they grouped/next to each other.
The Following User Says Thank You to Code05 For This Useful Post:
rjniles (09-15-2011)
Old 09-15-2011, 04:32 PM   #7
A "Handy Husband"
rjniles's Avatar
I would hate to cheat you that much, I will keep what I have.
Old 09-15-2011, 04:41 PM   #8
A "Handy Husband"
rjniles's Avatar
What I think I have decided on is to terminate the 10-3 UF in a 2 gang box with 2 20 amp switches. Then mount another 2 gang below (or above) that and install 2 GFCI receptacles. Then come off the load terminals of the GFCIs to my existing wiring for receptacles and lighting. (The outbuilding is already wired with a single 15 amp circuit (14-2 UF cable) that I am removing. The wiring in the building is 12-2 NM.)
Thanks for the help and interpretation.
Old 09-15-2011, 05:23 PM   #9
Code05's Avatar
lighting does not need GFCI protection.
Old 09-15-2011, 05:27 PM   #10
A "Handy Husband"
rjniles's Avatar
True, but the 2 circuits will have a mixture of lights and receptacles (unless I do more rewiring than I would like).
Old 09-15-2011, 05:31 PM   #11
Code05's Avatar
I am willing to send you 2 switches for the panel. Whadaya say?
Old 09-15-2011, 05:34 PM   #12
A "Handy Husband"
rjniles's Avatar
I pass, never know when I might find a use for it.
Old 09-15-2011, 05:38 PM   #13
Code05's Avatar
I am starting to think you are not falling for my silly offer.
Old 09-15-2011, 05:46 PM   #14
A "Handy Husband"
rjniles's Avatar
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
multi light circuit questions Temblor Electrical 7 07-11-2011 02:32 PM
change wire size in a circuit? mtmisfit Electrical 2 10-17-2010 01:07 PM
Splicing on 6 gauge wire paxprobellum Electrical 58 08-29-2009 01:22 AM
Wire size for dryer jamiedolan Electrical 14 01-15-2009 05:43 AM
