Multi-Phase Circuit Breaker? Maximizing My 8-guage Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 04:25 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by BillsBayou View Post
This is new, cut to order wire, so I don't think it's old.
Are you absolutely sure there is no ground? I can't remember the last time I saw a cable with no grounding conductor. It is basically useless cable.
If this came through a friend, WHY would he do that to you???
Please don't confuse an equipment ground with a ground rod. The required ground rod at the outbuilding has NOTHING to do with the required equipment ground run with the feeder. They are two very different things.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
mpoulton (10-01-2012)
Old 10-01-2012, 05:48 PM   #17
Sparky
Rewards Points: 510
can you take a picture of this cable?
8-3 rubber cord would be 3 wires, but 8-3 w/g UF would be 4.
Techy is offline   Reply With Quote
Old 10-02-2012, 10:16 AM   #18
My mistake. I'm at work trying to recall what I bought 5 months ago. It's 10-3 wire.
If there is any way to salvage this for part of the project, I'd like to know. Otherwise, I'm taking it to be recycled.
BillsBayou is offline   Reply With Quote
Old 10-02-2012, 10:24 AM   #19
Master Electrician
That cables wrong for a number of reasons. Where are you located?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-02-2012, 11:32 PM   #20
Louisiana.
So what is that I was sold? What is this wire good for? What should I have bought?
Old 10-03-2012, 01:09 AM   #21
" Euro " electrician
frenchelectrican's Avatar
That is pretty oddball combation cable you got there espcally with the colour format normally that colour format useally common over here in European side however we don't use that type of cable for many years without ground conductor in there.
So you will have to change to proper one 8-3 with ground UF cable the UF stand is underground feeder so that is the wording there and they are aviable in big box store or electrique supply centre.
One sérieux warning here you will have to use larger conduit if you are comming up from the ground espcally if the cable is flat verison.
Merci,
Marc
Old 10-03-2012, 02:57 AM   #22
Semi-Pro Electro-Geek
Rewards Points: 2,858
Louisiana.
I have no idea what that is. It's pretty weird. The colors are for a 208V three phase system, but it really is an ungrounded cable. That has very few possible applications these days. In fact, I can't think of any. What is the printing on the cable jacket? That should identify the cable type and help determine what it's supposed to be for. It almost looks like submersible well pump cable - but not quite.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-03-2012, 05:51 AM   #23
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is nothing in any of the OP post's that leads me to believe that he can do this job. Call an electrician.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
frenchelectrican (10-03-2012), Speedy Petey (10-03-2012)
Wire gauge / circuit breaker and metal clad to Romex FileOpen Electrical 6 03-01-2012 11:00 AM
breakers with multi wire branch circuit (shared neutral) corman Electrical 0 09-11-2011 12:52 AM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
