Multi Motion Flood Light System - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 03:12 AM   #1
Lightbulb
I am looking to set up a custom made outdoor motion activated security/flood light system. This will be installed around my house and yard. I would like to be able to have multiple lights and motion sensors in different locations. But I need all of the light to turn on at the same time if ANY of the motion sensors are triggered.
Can anyone give me an idea on how to achieve this? I am not looking for a pre build system as I would like to use my own custom lights.
kbmaintenance is offline   Reply With Quote
Old 03-24-2013, 02:36 PM   #2
Craftsman
Rab stealth motion sensors are rated for parallel connections. Use a three wire cable (with ground) between fixtures and sensors (use red conductor as the load wire on sensors and to feed lights. Just watch your maximum wattage of the circuit.
Superrick is offline   Reply With Quote
Old 03-24-2013, 03:31 PM   #3
Rewards Points: 13,300
It would be wired the same as a hard wired smoke detector I believe.
How to wire an exterior flood light to a new combination switch evm Electrical 6 02-01-2013 08:09 AM
adding a motion detector to a regular light fixture scotzilla Electrical 3 11-21-2012 11:00 AM
Flood light question impalabigblock Electrical 8 02-24-2012 05:04 PM
rough wiring garage for exterior flood lights with motion detectors jwalk2c Electrical 3 02-23-2012 08:53 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
