Old 04-17-2008, 06:56 PM   #1
Default multi fan control switch
I have 2 (probably they are over 20 years old) SMC fans with variable speed control that I need to replace in my living room. Both fans are connected to one variable speed switch on the wall. I've chosen to replace the fans with new Hunter Originals. Hunter technical support tells me that their Multi-fan variable speed control switch (22394) is for industrial use and will cause the new fans to hum. Meanwhile their standard capacitor H-M-L switch for Original fans (22691) is only 2 AMPs and is not rated for controlling 2 Original fans on the same circuit. I want to keep the original setup I have and control both fans on one switch. What are my options for fixing this problem? Hunter tech support says I should install 2 - 22691 switches on different circuits. I'd rather not do this if I don't have to. Hunter tech support also said the new fans might work on the old variable control switch. Is there another vendor that produces a switch like the 22691 that will work with 2 Original fans on the same switch, and not cause the fans to hum? What are the risks of running the new fans on the old switch? I haven't examined the old switch yet so I don't have any more info about it. Thank you.
dogwind is offline   Reply With Quote
More On This Topic
Hi I'm Mark Sullivan for Expert Village. Today we are going to learn how to install a ceiling fan in your home. Now we have just turned on our breaker again on the outside of the house so the power should be back on. I'm going to turn on the switch which... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here with expertvillage.com today and we just finished installing a ceiling fan in this house. I just want to take a brief moment and talk about dimmer... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a yard weed eater. Another area that you want to familiarize yourself with on your gas powered... Read More »
Hi, this is Jon on behalf of ExpertVillage. In this video clip, I'll be talking about switch operation. As with most woodworking tools, our belt sander has a typical trigger switch. When depressed, our belt sander will turn on. When released, our belt... Read More »
Hi! Mu name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a yard edger. Another area you will want to familiarize yourself with on your gas power yard... Read More »
3-way Ceiling Fan Dimmer? 47_47 Electrical 13 09-25-2007 11:31 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 03:19 AM
Hampton Bay Fan control switch vince Electrical 2 08-20-2006 07:00 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 04:53 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 10:43 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
