To Much Power - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2008, 04:21 AM   #1
To much power
Hi I am wonderinf if anyone can help me.
I am making a 3 bank reptile enclosure and want to know if it is possible to run 3 thermostats running 6 standard lights off 1 power lead. and 3 small 70W-100W Halogens off another power lead.
Or can I run this all off one power lead
marduk265 is offline   Reply With Quote
Old 04-01-2008, 06:32 AM   #2
Add up the Watts and divide by 120volts to get the amps.
If your at 12 amps, you are good for a 15amp breaker.
NAIL is offline   Reply With Quote
Old 04-01-2008, 10:27 PM   #3
Union Electrician
goose134's Avatar
Just remember not to wire the thermostats in series with each other. Wire them in series with the light you want to control.
goose134 is offline   Reply With Quote
Old 04-01-2008, 10:51 PM   #4
Thank you both for your help, I did think that it would be ok I just thought i check, better to be safe. I made up a quick diagram of what I was palanning on doing it would be much apprieciated if someone could varify that it will work fine
thanks agian for your help
Old 04-01-2008, 11:46 PM   #5
Idiot Emeritus
Rewards Points: 1,492
That'll work! As stated above, thermostats always go in series with the load, and parallel with each other. Just like you drew them. If they're single pole thermostats, put the hot (black) wires on the thermostats. The neutrals (white) splice through.
Rob
micromind is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
