Old 12-03-2010, 02:37 PM   #1
MR16 12Volt lamps
I have two low voltage recessed fixtures that came with MR16, 50 watt,12 volt lamps GU5.3, 2 pin base. Is it safe to use a MR16, 20 watt, 12 volt lamp in the fixtures?
Thank you,
Mike
Mike2401 is offline   Reply With Quote
Old 12-03-2010, 02:40 PM   #2
joed's Avatar
MR16 12Volt lamps
Lower wattage. I don't see an issue. It will be less heat.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
Mike2401 (12-03-2010)
Old 12-04-2010, 10:58 AM   #3
Electrical Supplier
MR16 12Volt lamps
If anything it would make the fixture, wiring and holder last longer due to less heat stress.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
The Following User Says Thank You to LyonsElecSupply For This Useful Post:
Mike2401 (12-04-2010)
MR16 halogen on dimmer to MR16 LED rrlangly Electrical 11 03-15-2010 10:36 AM
Attractive yet functional lamps for a house with small children? ChrisT Interior Decorating 6 09-25-2008 08:09 PM
Heat lamps Bob Bala Electrical 3 09-26-2007 06:37 PM
Outdoor Post lamps tennisnut Electrical 4 10-16-2006 03:48 PM
