-   -   MR16 12Volt lamps (http://www.diychatroom.com/f18/mr16-12volt-lamps-88497/)
Mike2401 12-03-2010 01:37 PM
MR16 12Volt lamps
I have two low voltage recessed fixtures that came with MR16, 50 watt,12 volt lamps GU5.3, 2 pin base. Is it safe to use a MR16, 20 watt, 12 volt lamp in the fixtures?
Thank you,
Mike
joed 12-03-2010 01:40 PM
Lower wattage. I don't see an issue. It will be less heat.
LyonsElecSupply 12-04-2010 09:58 AM
If anything it would make the fixture, wiring and holder last longer due to less heat stress.
