Moving Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2006, 12:12 PM   #1
moving thermostat
I want to move my wall-mounted thermostat over by approximately 1 foot; how hard is this?
thanks much.
gumby is offline   Reply With Quote
Old 12-12-2006, 04:29 PM   #2
Electrician
Rewards Points: 802
It depends if it is low voltage or line voltage(electric baseboard heaters)
If it is low voltage and you have the extra cable it will be easy. Just get the wire over to the new location and out the wall. Make sure you write down which wire goes where to save yourself more work. Even if you don't have enough cable you could always run a new wire from the furnace.
If it is for electric baseboards that may harder. You will have to get the wires out of the box and run to the new location. Then you will have to install a new box in the wall and run the wires into that and hook up your thermostat. If the wires are not long enough you could use the old box as a junction box and run new wire to the new location and put them in the new box. If you use the old box as a junction box make you put a blank cover over it and not drywall over it; you have to be able to access the junction box.
Hope this helps
Darren
darren is offline   Reply With Quote
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 02:36 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
Lux 722E Thermostat mgkicker HVAC 3 10-27-2006 01:40 PM
