Moving From Switch To Switch Combo, Please Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 04:13 PM   #1
Thumbs up
Moving from switch to switch combo, please help.
Hello,
I have an old switch that controls the light in my garage. I would like to make this a switch/ outlet combo. I had detailed pictures that are clearly marked, but for the life of me, I can't get this to work.
I have a multimeter and have taken readings in hopes this will help you help me
There are three pictures, one is the old light switch, the other is the light switch removed and the third is the new combo unit I would like to use.
How do I do this?
I'd appreciate any help you can offer! Thanks!
Jim.
Tritoon is offline   Reply With Quote
Old 08-31-2008, 05:27 PM   #2
Whatamess
The switch you have now is a three way switch. Also the power for the light is at the light. All your switch does is break the hot leg. Being a 3way is why you have the red wire. It is called a traveler. That is why you can operate the light from 2 locations or more. You will have to do something different on this. Since it is in conduit you might be able to pull more wire but I am not sure they make a 3way like you want to use.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-31-2008, 05:53 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I can't tell if the recep is switched by the switch or not. Is it?
Tell us what you want to end up with and if you have the ability to run new wires to this switch unit.
Not sure of your readings. Take voltage readings to each wire to ground. Then, as Tazin said, this appears to be a 3 way switch so there is another switch in this circuit. Go and flip that switch and then come and read the wires to ground again.
Old 08-31-2008, 10:30 PM   #4
3 way sitch = no neutral = not gonna happen.
220/221 is offline   Reply With Quote
Old 09-01-2008, 02:04 PM   #5
What about a Pigtail?
I don't want to have to run new wire and would love to just run with what I have. What about a pigtail to the receptacle?
I'll take some reading using ground rather than wire to wire.
Thanks for the help everyone!
Old 09-01-2008, 02:12 PM   #6
I don't want to have to go back to work tomorrow but........
Unless you rewire to eliminate your 3 way switch, it aint gonna happen.
For the recep you need a hot wire (which you may or may not have) and a neutral wire (which you don't have).
Nice pics and layout BTW !!
Old 09-01-2008, 03:29 PM   #7
My Best
The hard way it is then.
Thanks for all the help everyone and a most excellent forum!
Have a great day!
Jim.
Old 09-01-2008, 05:53 PM   #8
the Musigician
DangerMouse's Avatar
why not just get a bigger box and run the switch AND the outlets? too simple? the wires are there...
get a double ganger and put both in it. that new switch is a switch that when you turn the switch, it powers the outlet. (note led square spot on switch side) heck, throw in a gfci and you're fine, code states you must have gfci or old two hole outlets if ground is missing. (it looks to me like you have a hot, neutral and red return line, but no ground. if so, it should work fine. if i'm seeing wrong, sorry to waste your time guys.)
DM
Old 09-01-2008, 06:08 PM   #9
get a double ganger and put both in it. that new switch is a switch that when you turn the switch, it powers the outlet. (note led square spot on switch side) heck, throw in a gfci and you're fine. (it looks to me like you have a hot, neutral and red return line, but no ground. if so, it should work fine. if i'm seeing wrong, sorry to waste your time guys.)
DM
There is no neutral at the box.
jerryh3 is offline   Reply With Quote
Old 09-01-2008, 06:11 PM   #10
the Musigician
the old switch says black white red.... and they LOOK black white and red in the next pic. ummmm, you sure?
DM
Old 09-01-2008, 06:16 PM   #11
DM
The "black","white", and "red" were imposed on the picture by the OP.
Old 09-01-2008, 06:21 PM   #12
the Musigician
oic. that box pic is awful tiny but i think i do see the tape on the white line, so ok, my bad
DM
Old 09-01-2008, 06:25 PM   #13
the Musigician
i don't understand then, please explain to me how he can get a 120v reading with the black and the white, but can't hook up an outlet?
DM
Old 09-01-2008, 06:38 PM   #14
nap
You talking to me?
nap's Avatar
DM
if one the white wire goes to a resistance load (like an incandescdent light), you will read continuity to ground on that wire because it is hooked to ground. You will be reading right through the resistive load. It becomes a neutral wire after it leaves the lamp. If you put a recep in the circuit at the point we are dealing with, you will be putting the recep in series with the other load.
Not saying that is how things are set up here but the explanation is to answer you question.
just to explain the wire colors, or at least a possibility:
it looks like old NM cable which if using 12/3 and no ground, you could have the colors you see. What I think the deal is is, somenody stripped off the outer sheath of old NM 12/3 and this is what we are seeing. The white may be used as a switchleg to the load while the other 2 being travellers from the other switch.
Old 09-01-2008, 06:44 PM   #15
the Musigician
but.... there's no ground... still confused
DM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
removing a combo switch gresoul Electrical 2 02-18-2008 06:36 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
combo switch problem electric1 Electrical 2 06-11-2004 10:11 AM
