Old 02-23-2009, 02:07 PM   #1
moving a switch from the light to the wall
Hey everyone, in a new apartment I have a light with a pull string on it, and I want to replace the pull string with a standard switch on the wall. This is a small bedroom, and there are no signs of any previous switches having been on the wall before.
Please let me know if this is DIY material or if I would need a professional to come in or if there are any specialty products on the market.
justin2501 is offline   Reply With Quote
Old 02-23-2009, 03:56 PM   #2
Send a message via AIM to Bocolo
The easiest thing to do would be to buy a wireless switch unit. You would screw the unit unto the socket and the bulb into the unit and tape the switch that comes with it on the wall. Otherwise you would need to run a wire from the fixture to the new switch location. Not easy if you never done it before or understand how electricity works. Easy if you know what you are doing.
http://www.amazon.com/Carlon-HW2162-...ef=pd_sim_hg_4
Bocolo is offline   Reply With Quote
Old 02-23-2009, 04:19 PM   #3
If it's an apartment you better talk to your landlord first before changing the electric system.
Old 02-23-2009, 06:26 PM   #4
Ah sweet, thanks for the link Bocolo I'd been searching for remote switches but this one looks Much better for the job.
Also we've been taking a lot of liberties fixing up the apartment, which we worked into the arrangement with the landlord Jogr, I know it's not conventional but with a little TLC the apt is steadily approaching a 4 star from a 2 star.
Old 02-23-2009, 06:43 PM   #5
Not a problem. Good luck.
Old 02-23-2009, 09:17 PM   #6
Learning by Doing
Leah Frances's Avatar
Justin - keep ALL your receipts. See if you can negotiate LL to offset capitol improvements (my last LL paid 50% of my material costs when I moved out - and he was a first-class cheapskate). He paid when we moved out.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-02-2009, 12:57 AM   #7
Hi Bocolo. Rene here; I just registered. Great info. I've got the same problem, but in a closet and the chain has broken inside the fixture for the umpteenth time. I know how to run the wire to a switch, but it's really a pain to fish through these walls of mine. If I buy the wireless switch/socket combo, do I still need to hard wire a new fixture into the ceiling, or can I just use the one that the chain broke off of? The chain broke with the light off, if that makes a difference. Thanks in advance.
MurphyTXMom is offline   Reply With Quote
Old 07-02-2009, 04:21 AM   #8
Journeyman Wireman
Have to use the new fixture with remote
jbberns is offline   Reply With Quote
Old 07-02-2009, 08:13 AM   #9
I know I need to screw the socket receiver into the ceiling fixture, but you're saying (just for clarification) that I also need to hard wire a new fixture to the existing ceiling wiring? If that's the case, should it be another pull-chain type fixture? Thank you very much.
Rene
Old 07-02-2009, 08:19 AM   #10
A "Handy Husband"
rjniles's Avatar
If you can get the light switch to turn the fixture on, there is no need to replace it. Just install the remote. If you must replace, use one with a pull switch in case you ever want to remove the remote.
rjniles is offline   Reply With Quote
Old 07-02-2009, 08:27 AM   #11
Thanks a TON! I'll buy a new pull-type fixture today. Heckuva lot easier than fishing through insulated walls!
Old 07-02-2009, 10:43 AM   #12
Journeyman Wireman
A good solution for the closet is to use Wiremold (surface conduit system). Use a round Wiremold extension box at the light fixture box, run a switch loop to a switch box and you're done. Should not run to much for materials since it's a closet.
Jupe Blue is offline   Reply With Quote
Old 07-02-2009, 04:29 PM   #13
Thanks Jupe. The only problem with running wire in this house is that the previous owners installed insulation IN EVERY wall in the house. Fishing wire is not a big deal in hollow walls, but this house is proving very difficult every time I try to update/upgrade anything. Thanks again.
Old 07-02-2009, 09:05 PM   #14
The BEST solution for a closet light is a fixture with a built in motion detector. No switch required. Open the door and it's on. Works well for places like laundy rooms too.
220/221 is offline   Reply With Quote
Old 07-02-2009, 10:32 PM   #15
Hi. I thought about that, too. They are easier to find locally, but his closet has no door. Can't you set the sensitivity on those things, so the light will only pop on if he steps into the closet? Thanks.
Installing New Light Switch (NOT REPLACING AN EXSISTING ONE) Light Out on Hillsboro Be Electrical 10 03-11-2012 09:27 PM
Small flame behind light switch when off duffeymt Electrical 9 09-06-2008 12:05 AM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 06:51 AM
Wire hot with light switch turned off dangerouswithtools Electrical 3 06-17-2008 08:56 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
