Originally Posted by flynavy
Just wondering code for a bathroom fan. I removed a wall and am moving the switches. Does the fan need to be gfci? And If so can I splice the gfci off of the outlet. The fan is 2 foot out from the tub with 8 foot ceilings. I am not seeing any code that says it has to be but I have been told that it does. Please help.
The fan switch doesnt need be GFCI.. only the receptacle itself. Just place the fan, and bathroom light switch in a double nail-in plastic nm box that will take care of both switches in a separate box from the GFCI Receptacle. Here where im at.. its allowed by code. Passing inspection without a problem.
NOW::: Depending on how the current wiring format was before you disable them.. depending on how you will wire the two switch in place(as two separate switches still in the same dbl box).
