Moving Subpanel + Extending Branch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 12:18 PM   #1
Moving Subpanel + extending branch wiring
Hello All,
My question is in the last sentence, but here is the background:
I need relocate an existing sub panel that is now right next main panel in order to make room for a 200A Generator ATS.
From reading other posts in this form and others, I know an 8x8 inch or lager J Box can be used to extend the present sub panel branch circuit wiring - I will run new feeder to the sub panel.
I also know the neutrals can not be combined, and the j box must be grounded.
My question is what is permissible and cleanest thing to do with the ground wires. Do I need to splice them individually or can I screw a grounding bus bar into the J box? There are 12 circuits that need to be extended, a mix of 120V 15A and 20A, and 220V 20A and 30A.
Much appreciated,
Ray
raybo is offline   Reply With Quote
Old 09-04-2012, 12:51 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
If you have a buss bar, that is what I would use.
Run the largest conductor needed for the subpanel.
jbfan is online now   Reply With Quote
Old 09-04-2012, 02:24 PM   #3
Hi jbfan,
Thanks for your response.. just to clarify, it's ok to screw a grounding/bus bar to the back of the J box and tie all branch grounds to it, and also run a separate ground from the bar back to the sub panel using the same gauge as the largest conductor?
Thanks again,,
Old 09-04-2012, 02:50 PM   #4
jbfan's Avatar
Rewards Points: 478
Correct.
Garage Subpanel Wiring Question Joe85 Electrical 10 03-06-2011 03:14 PM
moving electrical outlet using aluminum wiring sjenkinz Electrical 3 12-05-2010 02:32 PM
Moving Subpanel loftezy Electrical 8 11-17-2010 11:39 AM
Extending electric wire when moving appliances docmattman General DIY Discussions 3 10-26-2010 07:06 AM
moving wiring runs in attic DoubleD07 Electrical 1 07-23-2007 06:44 PM
