Moving A Socket From Left And Stud To Right Hand Stud(and Up 3 Feet) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 09:27 AM   #1
Moving a socket from left and stud to right hand stud(and up 3 feet)
Hi,
basic question,
i am about to mount a TV on the wall and i want to replace the floor level socket with one at TV level. the down side is i need it to move from the left stud to the right stud and up about 2-3 feet.
my plan is to remove the lower socket put a blanking plate over it and just push an extra nm14-3 into the box and fish is to the upper location.
are there any considertaions that are needed for the wire moving from the left stud tot eh right stud in this application?
thanks
Raptor
raptor_demon is offline   Reply With Quote
Old 04-02-2012, 09:41 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You could use 14-2 and that would work if the circuit is on a 15 amp breaker. If it's on a 20 amp breaker it should be 12-2.
Use an old work box for your receptacle and you should be good.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-02-2012, 09:53 AM   #3
Thanks,
i forgot the ground was not included in the wire count.
is there any issue with crossing the wall cavity?
Raptor
Old 04-02-2012, 09:57 AM   #4
rrolleston's Avatar
I don't see any problems with crossing from one side to the other. Leave enough wire in both boxes to make your connections and you will be ok.
Old 04-02-2012, 10:02 AM   #5
Rewards Points: 2,516
Originally Posted by raptor_demon View Post
Hi,
thanks
Raptor
why not leave the existing outlet in its place at just feed the new outlet after pigtailing the existing outlet?
Moving a socket from left and stud to right hand stud(and up 3 feet)-new-bitmap-image-2-.jpg
hammerlane is offline   Reply With Quote
Old 04-02-2012, 10:03 AM   #6
thanks, will give it a shot.
Old 04-02-2012, 10:04 AM   #7
I thought about that, but decided to remove the old outlet.
The location is a baby's playroom so that is one less socket she can stick things in.
Raptor
Old 04-02-2012, 10:06 AM   #8
Raptor
Guess you can always add the outlet back in 8 years when you feel the kid is old enough to not stick things in it.
Are you also removing all other outlets 14" from ground level in the house?
The Following User Says Thank You to hammerlane For This Useful Post:
Jay 78 (04-02-2012)
Old 04-02-2012, 10:34 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
By code, that outlet probably has to be there, but its your house, and in the grand scheme of things, its not that big of a deal.
(I should amend that statement to read, I assume this is your house)
Old 04-02-2012, 11:07 AM   #10
Good catch.
The maximum distance between receptacles, measured along the floor line shall be 12 feet
-Glass door fixed panels in exterior walls are counted as wall space
-SLiding panels in exterior walls are not counted as wall space
While receptacles located more than 5.5 feet above the floor are permitted, they are not counted as required receptacles. 210.52
Old 04-02-2012, 11:42 AM   #11
rrolleston's Avatar
Since the old one is blanked off it can always be put back. If it's not needed I would do the same thing in my home.
Old 04-02-2012, 11:55 AM   #12
k_buz's Avatar
I agree with you...its not that big of a deal as I stated above, I do have 3 problems with blanking it off.
1) Where is the TV equipment? It is usually right below the TV.
2) If that outlet is needed in the future, what is easier, extension cord you have laying around, or reinstalling the outlet.
3) It may not be code compliant to remove that outlet. The code doesn't say that you can exclude outlets you won't use from the "6/12 rule"
Just pointing some things out that the OP may not have thought of...that's all...not arguing.
Old 04-02-2012, 12:30 PM   #13
Licensed Pro
It may also not be code compliant to add an additional cable to the existing box and retain the receptacle. So pick your poison
Old 04-02-2012, 12:42 PM   #14
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If your hanging a tv on the wall you will need the cable from the tv too in the location of the outlet.they sell kits to retro fit that will allow you to do just that.
As for weather running cable from the existing outlet or blanking being up to code ,worry about if/when you sell your house an if a home inspector even catches it.
sublime2 is offline   Reply With Quote
Old 04-02-2012, 12:46 PM   #15
@hammerlane
no, not going that far but i figured that it couldn't hurt to have one less around and i can always add it back in easily. Plus there is less of a chance of overloading the circuit, I'm not adding just moving the one that existed. maybe i will reconsider tonight when i have the wall open.
@k_buz
yes it is my house, and i will check but i think there is a socket within 12 feet on the same wall.
The TV equipment will be in the room directly behind the TV on a different socket with the HDMI,Component and IR cables running thru. The idea is to have just the TV on the wall.
@HouseHelper i will check the fill level of the box before i do this.
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
