I'll be installing a sub panel approximately 3 feet away from my main panel to accommodate extra circuits for my work shop. In addition, I want to move a few circuits from the main panel to the sub panel so I can free up some slots for a feeder breaker (main panel is maxed out).
It looks like the easiest way for me to do this is to mount a large junction box (of appropriate fill capacity) immediately adjacent to my main service panel and connect the two together with a large nipple (sized appropriately according to Chapter 9). I would then run an appropriate sized conduit from the junction box to my sub panel. I could then simply disconnect the circuit wires I want to move from their breakers in the main panel and run them into the junction box through the nipple. Within the junction box, I can wire nut them to wires that will run to the sub panel. I can also route my feed wires from the main panel, through the junction box and conduit to the sub panel. Does this sound acceptable?
I see in 312.8 that I can use overcurrent device enclosures as a raceway provided there is adequate space (40% / 75% fill as defined).
