Moving Service Panel To Pole Barn - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2014, 10:33 AM   #1
Question
Moving service panel to pole barn
I have a question for anyone that may have experience with this. I have a manufactured home that I have been remodeling. The main electrical service meter/panel is on a pole 10 ft from the house (L&I rules, I think). I am going to build a shop, and this Elec. service pole is right in the middle of the proposed shop's roll up door. I will need to move this somewhere, and I am wondering if it is allowable to just relocate it and attach the panel/meter to the side of the shop instead of relocating the pole to another part of the yard? The shop will be a Pole Barn and I believe that would be considered a permanent structure, right?
Appreciate any help.
exqqque is offline   Reply With Quote
Old 08-22-2014, 12:33 PM   #2
joed's Avatar
Rewards Points: 5,058
There should not be any problem with that.
The panel in the barn will be the main panel and the panel in the house will be a sub panel needing a four wire feed from the barn panel.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
exqqque (08-22-2014)
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 08:00 AM
Can you raise the roof on a pole barn after it's built? LMPD Building & Construction 12 03-24-2012 10:06 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
service at barn, sub at house? dick_linn Electrical 6 04-22-2011 04:47 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
