Moving Multiwire Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 01:15 PM   #1
I ask the impossible!
Rewards Points: 660
Moving multiwire circuits
For my future planning purposes, can anyone give me a run-down on what I will need to do with some of my existing circuits when I get to the point that I am moving them to my new 200 amp panel, which is located in a different room than the current 100 amp main panel.
Some background:
The 200A panel is going to be the main panel after my current project is done, the goal eventually is to move all circuits to the 200A panel. The 200A panel is currently serving the second floor and the kitchen, the 100A panel primarily is serving the first floor. No basement, house on crawlspace. The detatched garage is getting a 100A subpanel as part of the current project as well.
Most of the remaining circuits on the 100A panel are using 3-conductor cable, primarily 14-3 off of 15A circuits and 2 20A circuits using 12-3. Shared neutral between both circuits, then black going to one breaker and red to another. The 14-3 won't reach the new panel...
The new wiring will be done under permit and to 2008 NEC so these will need to be AFCI circuits (aside from the bathroom, which is more straightforward since it has GFCI... And I'll need to seperate the crawlspace outlets which need GFCI)
My question is if there's any way of using the 3-conductor cable, or if it's going to need to be replaced so I have neutral conductors for each circuit? And can I expect to find that these circuits probably have 12-2 or 14-2 for the individual branches?
I'm going to have to replace receptacles with TR receptacles too aren't I?
ETA: Just read a thread from 2008 that stated 2008 NEC will require double pole breakers for MWBC... Since AFCI is required and AFAIK there aren't AFCI double pole breakers, does this effectively mean MWBC's are out with 2008 NEC?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-21-2011, 01:36 PM   #2
Master Electrician
Rewards Points: 3,818
Siemens, GE, Cutler-Hammer and Square D all manufacture 2 pole AFCI's.
brric is online now   Reply With Quote
Old 06-21-2011, 01:49 PM   #3
Rewards Points: 660
Oof... definitely not at HD, and I just checked with my go-to eletrical supply store also and they don't carry Cutler-Hammer. My panel is Homeline so I the QO breakers won't fit. CH fits Homeline if I can find them, is that correct?
Old 06-21-2011, 01:57 PM   #4
Master Electrician
I believe I mis-read the catalog for SQ D. They apparently do not make a Homeline 2 pole AFCI. I think the CH BR series breakers will work in a Homeline.
Old 06-21-2011, 02:33 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
With your inspector problems, the last thing I would do is put a cutler hammer breaker inside a homeline box.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
HouseHelper (06-21-2011), SD515 (06-21-2011)
Old 06-21-2011, 07:12 PM   #6
Rewards Points: 660
Okay, I'll just approach this as a matter that it would be preferred to run new 2-conductor cable to eliminate the MWBC where possible, but if it for some reason seems to be problematic I'll consider a smaller sub-panel (might only need 60A lug or something like that) from a brand where double pole AFCI is more readily available.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
multiwire branch circuit question Jeremy Hillary Boob, PhD Electrical 9 11-18-2008 03:16 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
