Moving The Mast And Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2006, 03:47 PM   #1
MLO
Moving the mast and panel
For aesthetic reasons and simplicity in the main line routing, I am thinking of putting a new 200 amp panel in a mst. b/r. Any reason I should reconsider?
MLO is offline   Reply With Quote
Old 05-24-2006, 07:05 PM   #2
I don't understand how that could be aesthetically better, but that's your call. I don't think it's a good idea, but I don't have anything to back it up other than the code says the panel can't near (within so many feet) combustible materials such as clothing. I always like to see them in a hall way because nothing will ever get piled in front of it, and you could hang a picture in front of it if you like.
Sparky Joe is offline   Reply With Quote
Old 05-24-2006, 07:59 PM   #3
joed's Avatar
Rewards Points: 11,992
You can't put it in a closet if you were thinking of that option to hide it. You need a 30x36 space in front of the panel that is always clear. No dressers or beds etc in that area.
Old 05-24-2006, 11:35 PM   #4
MLO
I should have clarified my rationale...currently the feed line runs diagonally across the front yard to the garage, with-in about 5' of the front door and living rm. window. Moving it to the mst. b/r lets the line run down the side property line and out of your field of vision from inside the home. It also keeps the line higher off the yard as the grade is sloped.
Old 05-25-2006, 07:21 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Then just consider moving the mast, and refeeding the current panel where it is located. Do you need a new 200 amp panel? If so then replace the one you have. You may have to do some upgrading anyway, depending on local codes.
jbfan is online now   Reply With Quote
Old 05-25-2006, 10:37 AM   #6
MLO
Yes, a larger panel is being neccesitated by the remodel and as you guessed, local codes.
Old 05-25-2006, 06:44 PM   #7
What jbfan mentioned is a good way to go so you don't have to move all your branch circuits, unless a total re-wire is what you were planning?
Svc Panel location near G. Door wannabuild Electrical 1 01-15-2007 09:48 AM
Moving feed line and mast... MLO Electrical 4 01-19-2006 05:57 PM
