Moving Line Voltage Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 03:53 PM   #1
Hello!
I have an issue. I called electrical company, 2 electricians came by, they couldn't figure out how to move the thermostat without making a lot of damage, once they saw the set up, they said its going to run you at least 450$, originally was suppose to be 150$
So I told them, ok I will have to give it some thought and they left.
Another solution is to convert the boiler to 24v, but accordion to them, that's going to be as expensive.
Any ideas?
Thanks!
alexkn1 is offline   Reply With Quote
Old 12-28-2010, 04:29 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... Not sure what your asking, 'n your details a sketchy,...
Whereever you want to install a T-stat, a wire must be run...
Regadless the voltage used, the wire still has to be put in place...
Just how destructive that gets, depends on where you want the T-stat, 'n where the controlled appliance is...
Bondo is online now   Reply With Quote
low voltage inside conduit with line voltage teamo Electrical 1 09-26-2010 05:17 PM
Cat3 for thermostat line? gnosti83 HVAC 2 01-08-2010 03:06 PM
Low voltage thermostat wiring dirtpig538 General DIY Discussions 2 02-14-2009 01:48 PM
Moving a hard gas line. jadams68 HVAC 8 01-12-2007 09:40 PM
moving thermostat gumby Electrical 1 12-12-2006 05:29 PM
