Moving Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 01:04 PM   #1
Moving light switch
I should say moved, not moving. I moved around two light switches this weekend. The two switches were joined together in a double gang box, one switch controls an outlet in a nearby room (wanted to move this into the room) the other controls a series of recessed lights.
To do this I basically cut out some drywall and got into the attic and pulled the existing wire up (4 seperate runs of romex) out of the wall and connected it all into a double gang sized box that I installed in the attic. And then I added two new runs of romex coming out of the box to each of my new locations for the switches. My real problem is with 4 wires going in to this box in the attic and two coming out to switches I really ran out of space for stapling wires and the whole thing looks pretty messy by my standards.
Should I spend some time trying to organize and clean up the wires? I'm afraid some inspector some day might take a look at this and freak out. Or am I just paranoid? I should probably take a picture and post it.
lofar is offline   Reply With Quote
Old 05-05-2009, 08:31 PM   #2
So here's a pic. I guess it doesn't look that bad, I'm just a little paraoid and like everything I do to look neat and tidy.
Old 05-05-2009, 11:19 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
The only problem I see is the box may be too small for all the wires.
Old 05-05-2009, 11:53 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
That long white piece of romex coming off the top and around the side to the bottom may need to be secured closer to the box. I believe the wire must be secured within 12" of the box; I would assume that 12" is from the point at which the wire actually enters the box.
And yeah I have installed a few of those blue 4" boxes recently and I know that even if all those wires are 14 gauge that box is still way over fill capacity.
Looks like 2 - 14/3 and 4 - 14/2 wires. By my calculation that requires a minimum box capacity of 30 cu in. Those blue boxes are only 18 cu in, and with a 1/2" single gang mud ring it adds about 3 cu in.
Math:
2 - 14/3 = 6
4 - 14/2 = 8
All Grounds = 1
Total: 15
x2.0 = 30 cu in required space
theatretch85 is offline   Reply With Quote
Old 05-06-2009, 12:23 AM   #5
DIYer
What are those black wires?
Gigs is offline   Reply With Quote
Old 05-06-2009, 07:31 AM   #6
jbfan's Avatar
Rewards Points: 254
Some older 3x wire was black in color.
Old 05-06-2009, 10:11 PM   #7
Thanks... The wires are snug in the box but not forced, but I can get a bigger box easy enough. The top white wire should be within 12" of the staple, there's not much to compare for scale there but that particular space is only about 3 feet in height max.
You're pretty close on what all the wires are. The two blacks on the bottom are some of the old 3 wire romex, the two blues are the old 2 wire romex and the two whites are my new 3 wire romex to the switches.
moving a switch from the light to the wall justin2501 Electrical 14 07-02-2009 10:32 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
question moving light switch niemie13 Electrical 4 01-09-2009 03:12 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
