Ok, so after reading and reading and reading these forums, and other sites, I still don't know what to do, and I am pretty sure I am opening up a can of worms here...but lets see....
We want to move our fridge from the wall it is currently on to another wall that is more convenient to the flow of the kitchen. Can we? Is a dedicated circuit really required? Why is it recommended? Why is it not required?
See that all depends on the fridge that you have. If you have say a huge subzero than yes it is needed. But if you have a typical fridge than its not really needed. It all really depends upon how many amps the fridge draws and what is on the circuit your pluging into. But since your in the kitchen you most likely have 20 amp circuits depending on how hold your house is. So in my opinion if its just a typical fridge you can move it without running a dedicated feed.
Check the amperage it draws. Should be on the back? The max continuous load on a 20 amp breaker is 16 amps. But if it's not on a dedicated circuit already it shouldn't really matter. Turn off the circuit it is on and see how many recepts go off.
Does it have a dedicated ciruit now?
Main reason I like a dedicated circuit there isn't any chance anyone will overload the circuit & then the fridge is off
There is nothing that requires a refrigerator to be on an individual branch circuit, either for residential or commercial applications.(We always put refridgerator on its own circuit when we wire a new home)
A refer is NOT considered a continuous load, so as long as it is less than 20A on a 20A circuit it is fine. This is not to say that is the best way to go though.
In practice most of us do provide a dedicated circuit for a refer.
SInce you didn't say you where you are from I will add that in Canada the fridge has to be on a dedicated circuit.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
