Moving An Electrical Panal Box From Outside To Inside - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 06:19 AM   #1
Moving an electrical panal box from outside to inside
When they built my home I had my garage converted into a family room so they placed the electrical panal box outside, I 'd like to have it moved inside and if possible to have it recessed into the wall. At teh same time I'd like to have a generator add to tie into the houses panal box since we loss power so much. is this possible and what type of cost am I looking at.
rdwarfield is offline   Reply With Quote
Old 03-23-2013, 07:45 AM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Yes anything is possible if you have money. Abd for the price it all depends on factors that we can not even see, so its no way to tell
eastcoastsparky is offline   Reply With Quote
The Following User Says Thank You to eastcoastsparky For This Useful Post:
JulieMor (03-23-2013)
Old 03-23-2013, 08:28 AM   #3
Rewards Points: 12,794
Time to make some local calls to some real electritions.
In my opion not a DIY job at all.
He's also going to need to get a permit to do this.
Old 03-23-2013, 11:28 AM   #4
Note the fire department likes to have a main shut-off switch outside so they can easily turn off all the electricity if there is a fire.
Billy_Bob is offline   Reply With Quote
Old 03-23-2013, 11:49 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no requirement for an outside disco. None of my residential services have one.
Old 03-23-2013, 12:33 PM   #6
Always check local amendments. (Ask local electrical inspector's office.)
Old 03-23-2013, 12:44 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
I know what you mean.
Most in my area do require it, so it is standard everywhere.
jbfan is online now   Reply With Quote
Old 03-23-2013, 08:52 PM   #8
joed's Avatar
Rewards Points: 11,518
Must be a local thing. There is no such requirement where I live and I have not heard that one before.
Old 03-23-2013, 09:07 PM   #9
Not required here ether.
Old 03-23-2013, 10:04 PM   #10
Here is one... An Alaska amendment says this...
"23.30.230.70(A)(1) Disconnect at readily accessible location
Add a second paragraph:
The service disconnecting means shall be operable from the exterior of the
building if the service disconnect is within the building"...
http://www.muni.org/Departments/OCPD...20NEC_2011.pdf
Here is another local amendment for the city of Tempe...
"Article 230.70(A)(1) is hereby amended as follows:
230.70(A)(1). Readily accessible location. The service disconnecting means shall be installed at a readily accessible location either outside of a building or structure, or inside nearest the point of entrance of the service conductors. The service disconnecting means shall be installed adjacent to and accessible from the same working area as the utility meter.
All service disconnecting means located inside a building shall be enclosed within a room or space separated from the rest of the building by not less than a one-hour fire-resistive fire barrier."
The City of Evans, Colorado says...
"For a one-family dwelling, the service disconnecting means shall be located on the exterior of the structure adjacent to or combined with the utility meter enclosure. (Ord. 539-12)"
http://www.cityofevans.org/municipal...-electric-code
Etc.
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 10:32 AM
Run electrical through foundation to power lamp posts? Drywater Electrical 4 12-08-2010 12:39 PM
Moving oven and cooktop to island; need electrical advice worldtravelerall7 Electrical 3 06-17-2007 04:32 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 01:15 PM
