Moving Electrical Outlet Using Aluminum Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 11:01 AM   #1
moving electrical outlet using aluminum wiring
I am paneling a 30 yr old log cabin with pine planks. All the outlets in the cabin are set into the first course of logs so they are only 2 - 3 inches above the floor. If i leave them where they are, they will be covered with 1/2 inch plywood, 3/4 pine panel, and 3/4 baseboard (2 inch recess). I want to move them up about 18 inches and will have to splice. Also, all house wiring is aluminum. My question is, can I use the existing outlet boxes as a junction box if I put a blank cover on them and can I then cover them with pine paneling?
sjenkinz is offline   Reply With Quote
Old 12-05-2010, 11:23 AM   #2
You can't cover a junction box
It must always be accessible thru the blank cover
The Following User Says Thank You to Scuba_Dave For This Useful Post:
sjenkinz (12-05-2010)
Old 12-05-2010, 11:39 AM   #3
Oldguy
Rehabber's Avatar
Maybe this would be a good time to rewire and get rid of that aluminum wiring
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
The Following User Says Thank You to Rehabber For This Useful Post:
Old 12-05-2010, 02:32 PM   #4
joed's Avatar
Rewards Points: 12,356
If you leave them where they are you need to add box extenders so no wood is exposed inside the box. You can cover them with a blank cover. You can not cover them with panelling. They must remain accessible.
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 07:00 PM
Securing Electrical Outlet in Unfinished Room - Cement smohamed9 Electrical 2 04-04-2010 08:53 AM
I have a house with aluminum wiring should I pigtail every outlet guyblue Electrical 19 01-28-2009 07:07 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
