moving a CONSUMER UNIT
Thanks guys for mention moi .,
Ok the Customer unit is the same item as North Americian load centre.
The 16mm˛ is the same size as #6 AWG
Now to OP.,,
To order to move the CU you must get a hold of your electrician they have few items to dealt with it and it is not a DIY item to deal with it.
I will run summary what the British Electricians will do to move the CU.
They will do the following items.,
• Megger the unit
• Update the connections per UK codes
• will do other items as need to pass the requirement of FDE or other Power Company requirement.
The total cost that pretty much depending on the area.
Merci,
Marc
Reason: fix my error
