Moving Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 01:23 AM   #1
Moving Chandelier
Hey everyone. My wife and I bought our first place just about a year ago and I'm getting around to a few projects that I have been putting on.
We have a kitchen that is quite large and have our kitchen table in a different spot then the previous homeowners. Basically what I would like to do is move the chandelier that is in pictureA under the skylight in pictureB. Is there a way to convert the small recessed light and drape the cord hanging the chandelier on a hook?
Unfortunately this part of my kitchen is the only place in the house that does not have attic access.
Is the DIY possible or should I call in a pro?
homeownrnewb is offline   Reply With Quote
Old 09-19-2012, 02:06 AM   #2
Julius793's Avatar
If you got the money call in a pro less of a bother for you.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-19-2012, 08:20 AM   #3
Rewards Points: 2,512
How would you support the fixture if it was under the skylight?
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
gregzoll (09-19-2012)
Old 09-19-2012, 09:23 AM   #4
i have to agree with hammerlane, recessed lights arent heavy and dont require the same support as a chandelier. If you dont support it, it will fall just like mine did. Mine fell during transport, but still.
firsttimeremode is offline   Reply With Quote
Old 09-19-2012, 09:45 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Remove the recess fixture and replace with a ceiling mounted box. Extent the chain and wire and "swag" the fixture to where you want. You'll have to do some plaster repair aound the new ceiling box.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-19-2012, 09:49 AM   #6
I might have been a little unclear as to where I exactly wanted to hang the chandelier. My plan was to screw a hook into the support under the skylight using one of these http://www.homedepot.com/h_d1/N-5yc1...1#.UFnMg5h_Wg0 .
This wouldn't provide enough support for the chandelier?
Old 09-19-2012, 09:55 AM   #7
This is exactly what I was hoping to do.
Would this box work?
http://www.homedepot.com/h_d1/N-5yc1...1#.UFnO15h_Wg0
Old 09-19-2012, 10:04 AM   #8
electures's Avatar
Yes, but you won't be able to put it in the same hole. Just move the box in whatever direction the wire is coming from, then patch the old hole.
Old 09-19-2012, 10:05 AM   #9
ok the way you phrased it, it made it sound like you wanted to remove the recessed light and hang the chandelier there instead. what you are actually wanting to do might work.
Old 09-19-2012, 10:09 AM   #10
electures's Avatar
It'll work fine. I do it all the time. Just locate the box in the direction the wire is coming from otherwise it won't be long enough.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
Fuse for chandelier with 12-volt transformer? S_Jeff Electrical 1 08-16-2012 12:19 AM
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 02-01-2012 12:34 AM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 07:22 PM
Help for mounting a British chandelier in the US PaliBob Electrical 7 12-17-2009 12:00 AM
