Moving Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 03:01 PM   #1
Do work
Rewards Points: 81
moving breaker question
I'm installing an interlock kit for a generator. With that said, I need to move breaker #2 and #4 to the bottom to make room for my back feed breaker. The wire for these 2 breakers come in from the top and the hots are to short to reach the bottom of the panel. Can I just extend the hot wire using a wire nut and leave that splice in the panel? Or is this not correct?
Thanks.
liquidvw is offline   Reply With Quote
Old 10-04-2011, 03:22 PM   #2
Licensed electrician
Rewards Points: 1,884
Extending the hots that way is done all the time. If you were in Canada you could not extend them in the panel.
liquidvw (10-05-2011)
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 08:15 PM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 05:15 AM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 08:04 AM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
