Moving A 250 Volt Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 04:44 PM   #1
moving a 250 volt outlet
i need to move my dryer to another room. How do I go about moving the outlet to the other room?
housewife is offline   Reply With Quote
Old 08-22-2010, 04:45 PM   #2
Electrician
Proby's Avatar
It really depends on the circumstances.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-22-2010, 04:48 PM   #3
Licensed electrician
Rewards Points: 1,872
If you are moving it closer to the panel you might be ok. If you need to extend the cable run and it is not a 4 wire cable you will need to run a new cable back to the panel.
Old 08-22-2010, 06:40 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Can you possibly offer us some more detail?
The way you are asking my only reply would be call an electrician.
230 volt outlet in workshop jimmike Electrical 10 06-26-2010 02:16 PM
Need a 220 Volt Outlet in garage, what to do? gante Electrical 6 04-11-2010 10:53 AM
Should I replace a 240 volt outlet when getting a new AC sxn77 Electrical 18 05-08-2009 11:23 AM
3 Wire 220 Volt Outlet theatretch85 Electrical 5 07-29-2008 01:35 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
