Moving 22 Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 06:22 PM   #1
moving 220 outlet
hi everyone, have a new range which is too deep to allow opening drawers. want to move the 220 outlet from directly behind range at floor. have space below counter and want to move box and conduit there to utilize same material. working with 1/2 drywall over 3/4 furring strips on masonry. any codes or safety tips?
thanks
fathead is offline   Reply With Quote
Old 01-18-2011, 10:37 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
safety tip #1: make sure the power is turned off and verify it.
are you planning on a surface mounted junction box or trying to recess the box? With the materials you have a flush mount isn't possible as the shallowest standart box is 1 1/2" which is to deep to fit in the rock and on the CMU. You could cut a recess in the CMU if you wanted flush mount. I would strongly recommend a 2 1/8" deep box and likely a 4 11/16" swuare due to the size of the conductors will likely require it.
Do you have conduit or open cable?
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
moving a 250 volt outlet housewife Electrical 3 08-22-2010 06:40 PM
Moving a 220v outlet to a different room? seanfool Electrical 4 11-11-2009 05:33 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
