To Move Or Not To Move...the Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 03:30 PM   #1
the Musigician
DangerMouse's Avatar
to move or not to move...the panel
when i get around to the rear of this project, i'll be faced with what to do with the panel. i'm thinking i want a new, larger one for extra breakers because of the need to do it to code and having enough dedicateds to go around. right now it's in that drywalled square and the door is along the edge of an open 'closet'. ideally, i'd like to move it to the exterior wall, or is this a nono for some reason? i don't think it can be in a closed closet as this area will be when finished. maybe just turn it around and put it on the outside of the closet wall? also, since this will no longer be a 'mobile home' when i'm done, do i need to redo the wiring from the pole in copper instead of aluminum? (that was a real pain last time)
thanks!
DM
Old 02-23-2009, 07:17 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Why would you have to switch from AL to copper? I like copper and all, but whats your reasoning on the switch?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-23-2009, 07:38 PM   #3
the Musigician
i thought it was for mobiles only. so long as it's ok, i'll leave it.
DM
Old 02-23-2009, 08:52 PM   #4
Registered User
Termite's Avatar
Something to keep in mind is that the panel cannot be located in a clothes closet. In a pantry closet or mop closet is fine, provided the 30x36" clearance is provided.
Old 02-23-2009, 09:18 PM   #5
DIY'er
jamiedolan's Avatar
DM
Very few people have copper for there SE or the drop from the mast head. I might do it, but I'm a little nuts.
Jamie
Old 02-23-2009, 11:45 PM   #6
Registered User
Termite's Avatar
That makes two of us.
Old 02-24-2009, 04:31 AM   #7
the Musigician
se? masthead? this ain't a ship! what about putting it on the exterior wall?
DM
Old 02-24-2009, 05:34 AM   #8
DIY'er
jamiedolan's Avatar
DM
Can you post photos of the current service drop, how it is attached to the structure, the panel, and the surrounding area?
Jamie
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
