Move Light Fixture From Celing To Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 08:26 PM   #1
move light fixture from celing to wall
I have a swag-chain light over my vanity. Don't want it, want a wall mounted fixure which whould be about 10" over to wall and 10" down wall. Cut out all drywall between? Fish?
diyintn is offline   Reply With Quote
Old 09-09-2010, 09:14 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
depends how the building is built. If you have access to above (such as an attic), you can drill the top plate of the wall and fish a wire down the wall. Do you plan on leaving the box in the ceiling and putting a decorative blank plate on it or removing it?
The Following User Says Thank You to nap For This Useful Post:
diyintn (09-10-2010)
Old 09-10-2010, 05:33 AM   #3
I guess I was hoping wire would extend to new box without having to make a connection in the old box. I understand that if a connection is made at the old box, a cover has to be put on it for accessibility. Obviously I don't know much about wiring or else I would know if there is any slack in the wire in the wall for extending (just pulling wire over). I have cut and repaired drywall to install undercabinet lighting in kitchen by connecting to a wall outlet. I am not afraid to try something, just wary of danger. Guess I should go into attic. UGH
Old 09-10-2010, 06:12 AM   #4
I guess that is why electricians get paid the big money.
You may find that the route the wire takes to get to the ceiling box passes right over the top plate of the wall where you want the new light and that there is plenty of slack. Alternatively, given that you have access above, you could mount a new box (for connecting an extension, if necessary) in the attic and eliminate the existing ceiling box if you prefered not having the exposed cover plate.
While I don't mind drywall work, I would expect either option to be preferrable to cutting into your walls.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
Old 09-10-2010, 09:46 AM   #5
Thanks so much
Thank you both so much for your thoughtful answers and not telling me to go buy a book just because my name is Linda.
Old 09-10-2010, 12:27 PM   #6
Your name is Linda!? I thought it was diyintn.
Old 09-10-2010, 03:12 PM   #7
oops
oops, I gave away my age and sex.
Old 09-10-2010, 03:32 PM   #8
RST
DIY Homeowner
Rewards Points: 150
Your sure did!
http://www.babynamewizard.com/voyage...se&exact=false
RST is offline   Reply With Quote
Old 09-10-2010, 03:58 PM   #9
nap
You talking to me?
nap's Avatar
well, I didn't know your name is Linda but that doesn't really make any difference to me. I am a pro electrician and happen to know about a half dozen women electricians. Some are great, some not so much, just like the guys I know that are also electricians.
Electricity and DIY have no gender. If you want to try, are willing, are of at least average intelligence and do not want to be on the Darwin award winners list, we will try to help you do whatever you want to try.
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
replacing wall mounted light fixture donnakay78 Electrical 3 06-12-2008 08:07 AM
light fixture wiring jasjks Electrical 4 11-29-2006 02:51 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 01:16 PM
