Move Light Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2008, 10:48 PM   #1
Move light box
Hi, all
I'm moving outlet for lamp in bathroom from ceiling to the wall.
You think I can simply run 12 romex to new place from old box thru joists?
In our 25 yo building in CA, old fixture still has metal tubing, is it OK per code.
I also know that I have to keep old box accesible, right ?
Tx
Dai
dainova is offline   Reply With Quote
Old 06-01-2008, 01:13 AM   #2
If the building is wired in conduit it is very likely that you would be required to install any new electrical to the same standards (no romex).
Remember, there are other families at risk in a multi family structure. Have it done right.
220/221 is offline   Reply With Quote
Old 06-01-2008, 09:24 AM   #3
joed's Avatar
Rewards Points: 12,902
Almost anywhere lese in USA(except Chicago) you can do what you plan. I don't know if conduit is a requirement in CA. Check with the local code department.
Old 06-01-2008, 04:18 PM   #4
I assumed that she is in a multi family condo or something since she implied it was existing conduit.
Old 06-01-2008, 05:42 PM   #5
Yes, it's a condo and in CA
Old 06-02-2008, 02:55 PM   #6
The association MAY have restrictions on dooing your own electrical work (they SHOULD have IMO).
If you insist on doing it yourself, please use MC cable/connectors and do it right. It is a little more challaging but not that big of a deal.
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 03:52 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
need to move existing light. surfsupinhawaii Electrical 6 12-31-2005 08:54 AM
