Old 01-24-2010, 06:48 AM   #1
Question
move 2 switches new location, replace with 2 for new lights
Just browsing/searching topics for more info - but needed something straight forward
looking to move 2 light switches to a new location without ripping my ceiling/drywall
i have 2 separate track lights that run on 2 separate switches that i want to move to a different wall. i can access one of the wires direct from one light and i can see where the wire feeds down and goes to the switch - so i think i will unhook it and pull it to the light and fish the other wire that way too
then i need to work the wire to an unfinished part of my basement and i've got a heat duct with plenty of space around it and it actually floats under the floor joist with drywall built around it makes the ceiling low right there about a 2 feet wide low space that runs perpendicular to the joist
i'm thinking of fishing the wires along that space - not IN the duct
then i want to run new power to new switches running totally different new lights - to the old location - probably one power and then pigtail to the 2nd switch. looking to have 3 separate wires running the same area
the only reason i want to run the wires in the same place is because i think i can fish them that way
is this up to code?
qchawkfan is offline   Reply With Quote
Old 01-24-2010, 09:56 AM   #2
joed's Avatar
Cables are probably stapled to the studs. You most likely won't be able to pull the cable back.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-24-2010, 11:48 AM   #3
you'd be real suprised that it's not - i find so much not up to par
is it doable?
Old 01-24-2010, 12:15 PM   #4
joed's Avatar
It may have been part of a remodel. You don't need to staple cables when they are fished in finished walls.
If you can get the cables to pull through then go for it.
Outdoor lights (Soffit etc) DIY_JC Electrical 2 09-25-2009 12:45 PM
Replace Main Beam in different location? jrdamien Carpentry 5 01-10-2009 02:13 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 04:18 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
"Extending" wires to move switches blschmitz Electrical 5 02-12-2008 12:45 AM
