Mounting The Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 12:47 PM   #1
Rewards Points: 204
Mounting the sub panel
Thanks to Scuba_Dave I think I am ready to install my sub panel. I have a question regarding mounting the sub panel. What is the best way to secure the wood on the basement wall to mount the sub panel on? What thickness of wood is best to use?
Thanks.
Abs777 is offline   Reply With Quote
Old 02-15-2010, 01:24 PM   #2
Licensed electrician
Rewards Points: 1,870
I normally use a 1/2 or 3/4" plywood using 1 1/2" screws into plastic anchors. You could also use masonry nails, powder actuated drive pins or Tapcon anchors.
Old 02-15-2010, 01:27 PM   #3
Rewards Points: 204
For the wood, I was going to use liquid nail and then use the .22 ramset that I used to nail down my bottom plates. Do you think that would work?
How do you mount the subpanel to the wood? What size screw do you use for that?
Thanks.
Old 02-15-2010, 01:29 PM   #4
The adhesive and ramset would work, but you don't need the glue. A drive pin in each corner should work.
I normally use a screw to match the thickness of the wood to mount the panel.
Old 02-16-2010, 07:42 AM   #5
Rewards Points: 204
I have some left over 3/8" OBS that I was going to use. Do you think that would be too thin? Should I just go buy 3/4"?
Old 02-16-2010, 07:45 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Definitely 3/4".
I use Tapcons almost exclusively, and I have a professional ramset gun.
The ease of use with Tapcons is almost unfair.
I set one in the middle, then level up the board, and then set the rest.
Speedy Petey is online now   Reply With Quote
Old 02-16-2010, 04:06 PM   #7
Rewards Points: 204
What is your guys' thoughts of doubling up the 3/8". Would that be OK? The weather here is bad and I already have the 3/8", so it would save me a trip.
Also, should I cut the celotex so the wood sits against the concrete wall or can I mount the wood on top of the celotex?
Thanks.
Old 02-17-2010, 06:26 AM   #8
Rewards Points: 204
Anyone????
Old 02-17-2010, 04:24 PM   #9
Rewards Points: 204
Come on guys I need your opinions.
Old 02-17-2010, 04:43 PM   #10
I've only used 3/4" plywood ...I don't think it wil matter really
Code only requires that it be secured
As long as both sheets are lined up & it doesn't look ugly
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Mounting a panel to a concrete wall tigereye Electrical 4 08-21-2009 07:11 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
