Mounting Outlets In Hole Too Big... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 01:18 PM   #1
Rewards Points: 111
mounting outlets in hole too big...
Every room i have painted in our new house, I usually follow up and replace all outlets with new ones since the previous owners somehow painted all over them.
Anyway, i know this is minor, but most of the outlet box holes are cut slightly big, and and most of the boxes are recessed a bit from being flush to the finish surface...leaving me to put shims behind the outlet tabs so I can fully tighten the screws and not have a loose outlet...
....is there a better way?
redline9k is offline   Reply With Quote
Old 02-22-2011, 01:21 PM   #2
Coatings Nerd
buy longer screws
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-22-2011, 01:34 PM   #3
Licensed electrician
Rewards Points: 1,486
The electrical code requires that any gap larger than 1/8" around the box be repaired. The maximum setback from a non-combustible surface is 1/4".
Try these.
http://www.arlcatalog.com/Miscellane...0Extenders.htm
PaliBob (02-22-2011)
Old 02-22-2011, 02:03 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Those Box Extenders work great.
Go to an electrical supply house (not HD). They will also have longer screws if you need them.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-22-2011, 02:05 PM   #5
Rewards Points: 320
Are these currently metal boxes? Are these non-metallic cables (romex)? If so you can replace the metal boxes with the larger plastic old work boxes with clamps. Or you can use the box extenders that are shown in Jim Ports link.
teamo is offline   Reply With Quote
Old 02-22-2011, 07:20 PM   #6
Rewards Points: 1,578
HD does have them:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
They have them in different thicknesses as well.
bob22 is offline   Reply With Quote
GFCI Outlets in Series allbymyself Electrical 6 01-24-2011 11:52 PM
Outlets not working mackelroy Electrical 19 01-17-2011 10:22 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Triplex Outlets jamiedolan Electrical 33 10-14-2008 06:07 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
