Mounting Outdoor Floodlight - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 10:00 AM   #1
Mounting outdoor floodlight
What are the fittings needed to mount this light to an outdoor wall.
Thanks,
http://s481.photobucket.com/albums/rr173/s4325/
diysr is offline   Reply With Quote
Old 09-29-2011, 11:00 AM   #2
Rewards Points: 246
The mounting bracket is included. In the picture. You can't see it? If you want to know how to connect the power post that question.
Old 09-29-2011, 11:16 AM   #3
Licensed electrician
Rewards Points: 1,876
Is that a piece of flex cord on the back of the fixture?
diysr (09-29-2011)
Old 09-29-2011, 11:26 AM   #4
yes, its flex cord.
Is there any type of mounting box available to fix this or just screwing to the wall .
Thanks,
Old 09-29-2011, 11:38 AM   #5
All electrical connections need to be made in an approved junction box. You could surface mount a weatherproof box with a one hole cover. You would use a compression gland connector on the cord that would thread into the hole in the cover.
diysr (09-29-2011)
Mounting to Garage Ceiling stacyjkcmo Building & Construction 12 05-18-2011 04:14 PM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 01:56 PM
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 10:25 AM
Satellite Dish Mounting rjordan392 Home Theater 25 06-16-2009 10:59 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
