Mounting Octagonal Old Work Box In 5/8" Drywall?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 04:06 PM   #16
Rewards Points: 6,652
I know, but after reading their postings, they are over thinking this. From the way they are looking at it, it reminds me of some of the postings that we get on here from engineers, who are the worst when it comes to thinking out projects. If it was me, I would have done it the easiest and fastest way, and moved on.
Old 04-07-2012, 04:15 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can probably eliminate the box altogether. You should be able to run the wire directly into the heater.
Old 04-07-2012, 04:17 PM   #18
rkg
OK, so I had a homer simpson moment on the units - all changed now
rkg
rkg is offline   Reply With Quote
Old 04-07-2012, 04:26 PM   #19
k_buz's Avatar
Let me see if I get this...
You are fishing up inside the wall.
You are going to cut in a JBox
You are going to install flex from the cover of the JBox to the case of the heater
Why don't you just eliminate the box, mount the heater over the area the wire comes thru the wall and come into the back of the heater?
Old 04-07-2012, 04:30 PM   #20
They are going to have to have a box in the wall, where the wire comes out. Whether they use a cover or not, the proper way is to install the box to pull the wire through.
Old 04-07-2012, 04:33 PM   #21
k_buz's Avatar
What I'm trying to say is that he doesn't need a box...period. No box...No cover.
There should be a 1/2" knock out on the back of the wiring compartment of the heater itself. Knock that knock out out, and bring the 12-2 romex directly into the wiring compartment (using an approved romex connector).
Old 04-07-2012, 04:46 PM   #22
rkg
Ouch, I resemble that remark, or at least I used to until I moved to something Completely Different in life. Guess it still shows, huh?
(probably all the hassles with inspectors doesn't help - the ones around here always seem to dig pretty deep to find a "Persian flaw" on homeowners permits, and... My favorite was one installation where the guy found something wrong in the prior owner's work (that actually wasn't even mine/directly related to what I pulled the permit for) that his boss had inspected/approved years earlier, but I digress..).
I'm actually a big fan of fast/easy, and I'd normally I'd just stick in a rectangular box as you're suggesting and be done with it, but its a hassle to deal with the HOA every time I mess with something that is a "common element", and... (the solution shown would let me skate on that as its not messing with the envelope....).
I'm still a little leery of running romex in direct though, as this unit will probably get rented out from time to time and with my luck somebody will try and use that exposed run as a place for coat hangers and start a fire :-/
Best,
rkg
(Richard George)
Old 04-07-2012, 04:57 PM   #23
k_buz's Avatar
The wiring compartment is designed to have the wire run directly into it. They tell you in the instructions to do it and if you come into the back of the wiring compartment, there will be no exposed romex.
Old 04-07-2012, 05:16 PM   #24
Electrical Contractor
kbsparky's Avatar
If the OP really wants to use some metal flex, simply sleeve it over the exposed romex when it emerges from the wall.
No brainer ...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
gregzoll (04-07-2012)
Old 04-07-2012, 05:41 PM   #25
rkg
Thank you for taking the time to look into this.
Here's the data sheet on the particular units I've got:
http://www.rkgphotos.com/recent_stuf...stallation.pdf
The top view show a 1.5" gap between the back of the unit and the wall - I guess they are saying the heater's body provides "adequate protection"
then? I always thought you weren't supposed to any romex running out in space in a "public" area like this where it could be got at - shows you what I know
It must be the "correct" way to install it then (pretty much all of these units have the same setup - extended away from the wall on supports).
thanks,
rkg
(Richard George)
Old 04-07-2012, 05:46 PM   #26
k_buz's Avatar
If the romex is exposed the wall and the heater, but covered by the heater, it is considered protected from physical damage.
Old 04-07-2012, 08:41 PM   #27
jbfan's Avatar
Rewards Points: 654
If you havn't cut the hole yet, you could try this.
http://www-public.tnb.com/ps/fulltil...i?part=B117RSW
jbfan is online now   Reply With Quote
Noob mistake hanging work box, drywall up...now what? toobhed Electrical 19 01-08-2012 09:09 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 09:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
36" span to cover w/ 5/8" drywall Zhaar Drywall & Plaster 6 02-04-2011 03:18 PM
How is a drywall screwgun suppose to work? KUIPORNG Remodeling 10 11-03-2006 11:19 AM
