Mounting A Light To A Beam - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 01:46 PM   #1
Rewards Points: 150
Mounting a light to a beam
I have a center ridge beam, roughly 6x14 spanning our raised ceiling. The rock will hit the beam about 10" from the top, leaving approx 6"x4" of the beam exposed. We will be installing (2) hanging lights from the beam.
What is the best way to rough in the wiring so it looks ok? A standard Jbox attached to the bottom of the beam is kind of ugly. The light has a standard cover that would cover a junction box that is flush to the ceiling, but it is not deep enough to cover the full depth of a box hanging from the bottom of a beam.
steve1234 is offline   Reply With Quote
Old 10-19-2007, 03:06 PM   #2
you could mortise a pancake box into the beam, if it were ok to drill into the bottom of the beam. I wouldn't expect that a 3"x1/2" deep hole would be a problem in a 6x14 beam but I don't know the rules on that. You could drill diagonally through the beam from the pancake box up into the ceiling space (behind the drywall) to conceal the wire.
NateHanson is offline   Reply With Quote
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 12:41 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Hanging a beam/rafter from a beam snmhanson Building & Construction 4 01-11-2007 11:37 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
New porch light CB-PDX Electrical 4 03-09-2006 01:17 PM
